Man of Honour
- 21 Nov 2004
Would I be crazy going for a 7900XT? Price seems decent currently, 1080Ti getting a bit dated, especially to drive an OLED above 60hz.
7900xt is awesome, but it’s a Crappy deal in terms of for 100 more you get like 30% extra perfWould I be crazy going for a 7900XT? Price seems decent currently, 1080Ti getting a bit dated, especially to drive an OLED above 60hz.
42? Make sure you have at *least* 70cm depth, ideally 80/90cm. Unless you're a Mr Magoo boomer like meI just need to double check whether my planned screen will be too big or not for my desk.
42? Make sure you have at *least* 70cm depth, ideally 80/90cm. Unless you're a Mr Magoo boomer like me![]()
I run a PG42UQ on a 60cm depth and think it's a *little* bit big, thinking of one of the new 32's that are coming but the 34" AW OLED also seems a better fit atm on an arm (little closer and also the better gaming screen).50-60cm max I think. Maybe it’s too big![]()
looking at the spec of your monitor it says it has a native refresh of 144. I’d give it go. Set your maximum refresh in Radeon chill to 143 and off you go.I can't make my mind up on a replacement monitor. Still running a Dell S2716DG at the moment, which only has G-Sync so no use for my new card either. I wouldn't mind a bigger monitor, but that also means stepping into either ultrawide or 4K. Then it starts getting pretty expensive.
I may end up getting another 27" 1440p 144Hz monitor but with Freesync as a stop-gap. Then find a better monitor further down the line. I have a 65" 4K TV attached to my PC also, mainly for Flightsim.
What/How long for? Do we know?LtMatt is banned from the gfx forum for being a complete donk![]()
He's a nice guy tbh, just fell in with the wrong crowd on gfxthe guy is super helpful cpu forum.He goes out of his way,good stuff.
@LtMatt & maybe others what is the hotspot thottle limit for 7900xtx, seeming to see very conflicting reports of "safe"
If your using a aircooled card i would say around 80-100c on the hotspot is where you want to be, aib's will run cooler though, if you dabble in watercooling the hotspot is stupid low, i should know my WC 7900xtx MBA, peaks around 45 core and 59/65 hotspot in gaming load at 4k. if any 7900 series card goes past 100c upto 115c then you need to look at a repaste, if your not confident and you still have warranty on the card contact the support channels to arrange a RMA.
What rads are you running in your system?
