- 20 Apr 2009
I finally got round to doing mine, but managed to blow up my cheap Lidl leaf sucker thing. Back to wooden paddlesI need to do this too but just can't be bothered!
How did you manage that?! My father in law has one of those so need to avoid doing that!I finally got round to doing mine, but managed to blow up my cheap Lidl leaf sucker thing. Back to wooden paddles
You'd have to subscribe to his OnlyFans to seeHow did you manage that?! My father in law has one of those so need to avoid doing that!
Think it took up a bit of very thin branch / twig which got stuck. Only very spindly stuff. Started smelling of burning, then quickly died.How did you manage that?! My father in law has one of those so need to avoid doing that!
Yes exactly!!!Haha reminds me of this clip
Thanks. No just used an old blunt first fix panel saw. It’s what I use for cutting through the insulated plasterboard too (apart from track saw for the mitred cuts). Don’t use a fancy saw through it, plasterboard dulls the saw quick.Very helpful! Looks great. Will be nice and warm. Did you trim it back with anything special or just a blade/plasterboard saw?
Thanks. It’s a double brick wall, but solid with no cavity (so no insulation). External wall insulation isn’t really feasible at the moment so going for internal.Wow @Mason- that's quite a job. Is it a single skin wall and therefore cold that motivated you to do this?
Is this a solid brick house with no cavity? Have you noticed much of an improvement after adding the insulation?Prepared and fitted insulated plasterboard to window reveal and walls. If anyone’s interested it’s kingspan K118, 37.5mm in the reveal, 62.5mm on the walls.
2 more bits to do tomorrow.
Window reveal top:
You cut it deeper than the depth of the reveal, for the wall boards, 62.5mm, plus some excess wiggle room ~20mm or so.
Same on the sides
Trim the insulation off of the protruding parts leaving just board protruding:
First piece cut around, here you can see the extra wiggle room of the protruding board, will trim it flush later. This job wouldn’t be so bad except for mitring this stuff to the ceiling. Used a track saw, it’s very hard to keep a hand saw at a steady angle through 1.2m of board.
First two awkward bits done. Last two are easy.
And finally here is a little bit of the protruding board I trimmed flush, will give the PU adhesive as long as possible to go off before I trim it finally:
Yeah it is. Too soon to say for this room, was only 2 days ago, and there’s no rad there yet, as well it’s been really mild.Is this a solid brick house with no cavity? Have you noticed much of an improvement after adding the insulation?
Are you just using adhesive to the wall, or glue and screw?I did the single skin porch with 40mm pir and then 40mm tileboard, it's been a game changer.
