Fair enough. You’ll just have to drink more coffee.No room in the Freezer. I don't like to freeze coffee anyway.
It’s a great machine. 3.5 years into mine (4000 shots) and cannot fault it. Beyond routine maintenance the only thing I’ve had to change are two safety valves which was a bit daunting a first but fairly straightforward once I watched a few YouTube videos.Treated myself to a Bianca, best decision I have made. Just waiting on the DF64 grinders to come in stock now at BB
Yeah the v2 is supposed to have fixed the little things, fingers crossed. Popping into BB today so will see if they have had a shipment yetIt’s a great machine. 3.5 years into mine (4000 shots) and cannot fault it. Beyond routine maintenance the only thing I’ve had to change are two safety valves which was a bit daunting a first but fairly straightforward once I watched a few YouTube videos.
I’ve a first gen DF64 and it’s a good partner with it - the newer ones look like they fix all the idiosyncrasies on mine. Enjoy it.
Very nice. I bought a Mara during lock down 1 and it's been used every day since, great bit of kit. I bought the walnut knobs and portafilter from the Bianca to jazz it up.Treated myself to a Bianca, best decision I have made. Just waiting on the DF64 grinders to come in stock now at BB
have you applied the stepless mod on the grinder .. least ways for a rancilio grinder a similar modification was revelatory , discrete steps had used to change the extraction time by 10s+If I was looking to improve my setup
whose water have you used ? - or adam's ales ok in your region.It’s a great machine. 3.5 years into mine (4000 shots) and cannot fault it. Beyond routine maintenance the only thing I’ve had to change are two safety valves which was a bit daunting a first but fairly straightforward once I watched a few YouTube videos.
I'll have look at the puck rake and level tamper.Filter screen nope, waste of money.
Spinny puck thing nope.
A puck rake yes (you can home make with 0.3mm/0.4mm acupuncture needles)
If your technique is off a level tamper but the one extra tool that will actually benefit will be the rake
Not that specific mod, but I did mod the grinder to allow it to grind finer (forget what the mod was called now).have you applied the stepless mod on the grinder .. least ways for a rancilio grinder a similar modification was revelatory , discrete steps had used to change the extraction time by 10s+
Any websites/brands worth looking at or should I just go with something highly rated on Amazon?
interesting - I use brita for tea, but would not be able to provide, probably 2L a day cost-efficiently/conveniently for espresso machine.Osmio zero water from new so just bad luck on the valve front
How hard you tamp isn't that important. 9 bar of pressure will compress the puck way more than you can tamping. Back in the day I've had those clicky pressure Tamps and I used to practice on scales to get a feel for what 30lbs is and imo it's just not that important.The rabbit hole deepens and I now realise that I need a dosing funnel to avoid spooning out the grinds from the scales on my grinder. That and a rake and we’re getting there!
Now that I’ve got a bottomless portafilter - how hard should I be tamping? I’m really putting my shoulder into it to get a well formed puck at the end of it. Seems to be getting more out of the coffee too without bitterness, so I’m taking it as a win for the portafilter and the finer grind that I can now use compared to the double layer standard one.
So we have a salt based house softener as we’re in London and the waters awful from a scale perspective. I feed the softened water to the Lelit via the osmio RO system as softened water is easier for a reverse osmosis system to filter. Net result is 30-50ppm water that doesn’t scale the Lelit. The osmio does remineralise the water and the coffee (to the 30-50ppm) tastes great to me. I have previously faffed about with distilled water and third wave sachets but decided the taste benefits weren’t high enough to continue given the cost and faff.interesting - I use brita for tea, but would not be able to provide, probably 2L a day cost-efficiently/conveniently for espresso machine.
(usually burn water for heating cups and flushes as bezerra is an hx)
my concern on house wide mains input softeners is that, in comparison, they wouldn't provide acceptable taste for espresso, my top priority
The big things that help your espresso are:
- Bean and roast quality (partly down to taste)
- grinder quality - more even particles means less over and under extracted stuff
- machine quality - consistent temperature and pressure mean you can make adjustments to the grind level to get the right level of extraction
- Bean & puck prep
- Spritz the beans with water to minimise static
- WTD (stir the grinds with one or more needles) to get rid of lumps and even out the distribution
- tamp to pre-compress and level out the grinds - gives more even extraction across the puck (so the water flows more evenly through) - as mentioned before the most important thing is its level, not exactly how hard you compress.
- puck screens or paper above and below also help even out extraction.
