I removed enough for a loft hatch and that tiny section must have weighed in excess of 30kgs. It was "PROPER" and the way it oozes through above means its pretty bullet proof - however, the nails fail and the laths sag and then it's all downhill from there.
Few Qs:
This window was fitted with massive gaps either side. Can I just foam these? 1930s solid wall.
Second Q:
I am debating a digital shower again, because you can get ones that just drop from the ceiling and this seems quite simple. However, they are SUPER expensive and I loathe to be unable to shower because the powers out.
Can I chase out the wall sufficiently enough to do a typical bar type setup? It is single skin clinker but allow 10mm or so for plater and the another 4mm for tile board - will I get 90 on the copper and not **** it up?
I can't remember how you even fit these - and before I had access behind the wall......
