At least compare like with like instead of cherry picking sale items because you said "7600", not 7200 and listed a 7200 kit anyway. Then also ignored the least expensive DDR5 6000 kits while showing the DDR5 7X00 kits that are on sale. DDR5 7600 is in general £70 - £160 more expensive than the cheaper DDR5 6000, I just picked an average price difference for a comparison.
It is possible to get 32GB of DDR5 6000 C38 non EXPO that can be tuned for a touch less than £100 now. So a difference of £65 if we go by your picks and considering some of those 7600 kits are £200+ you can see how zero cost/perf benefit some of them would give. The impact on R9 7XX03D system performance for that £65 (or usually more) would be to all intents and purposes ZERO.
You also forget that your DDR5 6000 C30 RAM can be overclocked if required?
I specifically picked the £130 EXPO DDR5 6000 C30 for the plug and play no hassle benefits and paid a £30 premium for it. So that £30 wasn't some potential "future proofing", it was an actual benefit I was getting right now.
