- 31 Jan 2022
- UK
1440p and 165hz
Do you cap that in the NVIDIA Control Panel? I just wonder if it is running too fast for the CPU. Maybe you could try capping it just to see?
1440p and 165hz
I have it set at 165 in control panel.Do you cap that in the NVIDIA Control Panel? I just wonder if it is running too fast for the CPU. Maybe you could try capping it just to see?
3d Mark results are
27668 gpu
11821 cpu
From the results on Guru3D. For Timespy: the CPU and GPU scores are more or less correct, maybe a bit lower than usual, which could relate to the memory speed, but certainly nothing that would explain poor performance in games.The free direct 12 gaming pc one. I didn't alter anything on the settings just pressed run.
Just crazy how I had warzone running nice on my 3090 and now getting less fps and running terrible.
you're sure that your cpu is not throttling due to being too hot, thus starving your 4090 of cpu power intermitently?. Cpu hitting 75 degrees.
Oh my god. I'd never thought of checking that... I checked and they're not running!Check that the fans on the GPU are working.
edit: It seems they do work but only under stressPhew.
Thanks for making me check![]()
I'm unsure how I would check that? I didn't thunk 75c was too hotyou're sure that your cpu is not throttling due to being too hot, thus starving your 4090 of cpu power intermitently?
that is my first thought anyway
It's the 4080 super gigabyte.Which 4080 is it?
I will check this.Do you have gpu- z? Check what pci-e speed its showing while loaded. It maybe defaulted to something like pcie 3.0x4.
1200w rog psuWhat make and model is the psu? How are you powering the gpu, a single lead from the psu using the daisy chained connectors plugged into both cables of the high power adaptor cable, a pair of seperate cables from the psu plugged into both cables on the high power adaptor cable or even a dedicated high power cable straight from the psu?
Which Gigabyte model as they have a few supers?It's the 4080 super gigabyte.
The windforce one.Which Gigabyte model as they have a few supers?
Installed a new 4080 super. Did ddu etc. Now getting terrible stuttering and dropping fps in game. Cpu hitting 75 degrees.
i9 10900k
Am I being bottle necked by cpu?
if you monitor is 165Hz it's advised you set a max of 164 in control panel as setting it the same as the refresh rate can cause visual problemsI have it set at 165 in control panel.
Turn up game setting a lot. Set them all the max. And retestI've ran the logs bit no idea how to post them to the forum?
I noticed my cpu is at 99% a lot of the time and my gpu is only around 80%.
