- 30 Mar 2020
not the stream in game. Its worse when its say a built up area and the computer has more to do.lag in the stream is nothing to do with a GPU
you did update the bios right?
downloaded it but what am i looking for>?Can't see it
May as well download it and have a look.
ive set it to record max readings i will play a game and update back. thank you all.open the program, and run something 3D at the same time like a game..
then take a screen shot of GPUz and lets see it
i think ive done it.
Vapor Gaming
Vapor Gaming. 859 likes. Gaming content, ps4, PC and xbox. Switched to mouse and keyboard in August! call of duty warzone streaming 7 days a week!www.facebook.com
no other cards in the motherboard, ive not checked the lane speed. I dont know a great deal about computers im learning as i go.According to that it’s running at x8, 3.0. Not 16x 4.0. Do you have other PCIE cards installed? Have you checked the BIOS lane speed?
That part is normal at least, with the 10900.
Yep, you’re right.That part is normal at least, with the 10900.
So it should be running on 8x?Yep, you’re right.
Fair enough. In windows click start, type cmd and run as admin. Type shutdown /r /fwno other cards in the motherboard, ive not checked the lane speed. I dont know a great deal about computers im learning as i go.
What's the motherboard?So it should be running on 8x?
If the 4080 is the only PCIE card in use, then it should be x16. Do you have multiple NVME drives as they could reduce your bandwidth to x8 but then it would have on the 3090 too.So it should be running on 8x?
Rog maximus hero xiiiWhat's the motherboard?
