 - 30 Mar 2020
So I've downloaded fortnite to test another game and it was simply unplayable with the auto settings. I've had to drop them all to pretty much low to get any decent fps. And still not 165
Thanks I will have a look at this tomorrow.Ive just been looking at your photos on face book and if you card is running stock... thats it will throttle at 82c and your hotspot is 85c max, your power usage is again at 330w massive and its hitting the limit for everything.
you need to install MSI afterburner and undervolt the GPU, there is a lot of youtube videos for this so im not going to explain step by step...
just go on youtube and search 4080 undervolt
also memory usage at 96% is not good.
not the best but....
- YouTube
Enjoy the videos and music that you love, upload original content and share it all with friends, family and the world on YouTube.www.youtube.com
again 100 is good for your system..100 randomly and very often.
Reinstall windo
Reinstall window
 Fingers crossed!Going to try leaving the files there first then go for the big one.Just nuke it so there's no trace of anything, cant beat a clean install when troubleshootingFingers crossed!
Copy the files to another disk before wiping outGoing to try leaving the files there first then go for the big one.
Fair enough if you've got twice the time to waste to find out, I'd just back stuff up drag and drop to usb drive/external hdd and do a clean install.Going to try leaving the files there first then go for the big one.
