- 19 Apr 2013
- Scotland
The Scramble effect from what I've used switches your strats around if they're off cooldown and then does the correct one if it is. They're only randomised once though, so if you can remember which one they've moved to you can call in the one you want. Or as normal, try and call a support and check if the ball in your hand is blue or red
ie something like:
#1 > #3 but if #3 is on cooldown then does #1 as normal.
#2 > #1 if #1 is on cooldown then does #2 as normal.
I've had more problems with trying to call in a cluster/500kg bomb and then getting hit by something that rag dolls me and therefore drops the bomb right at my feet. Queue team kills and some unhappy people yelling wtf!
ie something like:
