I've stuck with a 1080Ti. So I deny your denial of my denial.Nah, you lot would pay £3000, stop denying it.
They know their frothing at the mouth fan base will pay anything, They could charge £3000 for the 5090, £2500 for the 5080 and £2000 for the 5070 and Nvidia uber fans would lap it up.
I was reading about the quality of the games on Playstation from their 1st party studios and comparing that to the new Forza and Starfield, and it just made me think get a PS5 Pro and keep my 3080 for Indie games.
I would only get the 5090 under a few circumstances:
To pay up to £2,000 would require 60-70% more performance, which doesn't seem likely. I could also do £1,800 for 50%, so quite a few options...
- At least 35% faster than 4090 (which is approx 25% improvement in cost per frame)
- Same MSRP (or less)
It's difficult to see the 5090 being a huge improvement. The 4090 was a huge improvement because Nvidia went from Samsung 8nm to TSMC 4nm , that gave a massive increase in transistor density and power efficiency savings which was used to boost the core count by 60%, boost clocks speeds by 50% and boost L2 cache by 1200%. The 5090 will be on tsmc 3nm, which does not have those same transistor density and power savings increase, so it becomes difficult to see how they can get a significant gain if they keep the same architecture, unless they make a massive GPU die with 600w TDP, that's always possible but a bigger GPU will come with bigger price, probably $2.5k
Over 2 grand is far to expensive new twch ir not yes some people will pay it buts its a lot of money .
so it must be true then, that dog walker has always been a reliable sourceUsing AI they improved their GPU architecture apparently. MLID heard it from his mate's brothers, cousins dog walker.
I'm with you on this. £2k would need to be a big improvementI would only get the 5090 under a few circumstances:
Using a less cut down chip of 95% instead of 89% would get you +10%, the higher bandwidth from GDDR7 another +10% then add +20% for the new 3NM node and 15% for architecture improvements and your already at +55% so not to dissimilar to the +70% which the 4090 has over a 3090.It's difficult to see the 5090 being a huge improvement. The 4090 was a huge improvement because Nvidia went from Samsung 8nm to TSMC 4nm , that gave a massive increase in transistor density and power efficiency savings which was used to boost the core count by 60%, boost clocks speeds by 50% and boost L2 cache by 1200%. The 5090 will be on tsmc 3nm, which does not have those same transistor density and power savings increase, so it becomes difficult to see how they can get a significant gain if they keep the same architecture, unless they make a massive GPU die with 600w TDP, that's always possible but a bigger GPU will come with bigger price, probably $2.5k
Yeah!! At least i *admit* that I have a problemYou will still buy one. Just like last time. You said you wouldn't, but caved in![]()
Terminators always wore leather jackets.They are using AI to design GPU's now? that's impressive, that AI can do that, also scary.....
