5800x3D upgrade
10 Aug 2023
Glasgow
I swapped my 5600X for a 5800X3D just after Christmas and it was (as expected) running hotter. So I bought a Thermalright Peerless Assassin last week, adjusted the fan curve and is now running at a perfectly acceptable temp and super quiet. So impressed with both. As a final Hoorah for the AM4 it was a great swap after flogging the 5600X.
I just installed mine over the weekend coming from a 5600x. I already have a Corsair AIO (H100i or something, can’t recall) so the temps while gaming haven’t pushed above 50C. Although i need to give it a proper run with more cpu intensive games, i did run the cyberpunk benchmark and another benchmarking tool.
Very impressed so far, the cyberpunk benchmark was definitely more stable and the whole system does feel a bit snappier (even before i reinstalled windows).
Perfect last hurrah before retiring my AM4 kit, what a platform it’s been.
10 Aug 2023
Glasgow
Apart from just wanting a fresh start with the PC after installing the new CPU i’d had issues uninstalling a couple of apps. The primary culprit being the garbage noted above.
Now happily RGB free, for the most part, but there was remnants of their software i just couldn’t get rid of. This is also the 3rd CPU and I’ve had 3 GPUs (2 nv and currently amd) in this system without reinstalling windows so this was the perfect excuse to do it.
11 Oct 2015
Just installed mine not seeing much of a benefit just yet but its early days and also knowing this will serve me for another 3+ years is helping lol
Currently running at around 49c in games at stock so Im happy with that my 3700x was around this too
10 Aug 2023
Glasgow
Same - this should do another 2-3 years, at which point AM5 will have matured, cheaper prices and so on.
I was expecting it to run hotter than it is, pleasantly surprised.
24 Jun 2022
Manchester
I have my curves set as said above and hit 54 max on The Last Of Us and 51 it sits at on The Quarry. Pretty much same on my 5950x but I think the h150i on that system fans are running a bit faster like 300 RPM extra. IIRC. I do like this 5800x3D.
6 Apr 2009
Liverpool
I am thinking about going RGB free aswell might take a leaf out of your book and do it.
10 Aug 2023
Glasgow
It’s so much less hassle. At one point i had two different lighting apps. ICue and whatever the steelseries one is called. I got sick of those, tried to delete them (i now loathe iCue due to the hassle that caused me) and then installed openRGB. Eventually i just thought ‘why the hell am I ******* about with this crap’ so replaced my 280x case with a fractal north and got rid of the rgb fans on the AIO.
Also got a keychron keyboard which does have rgb but it’s controlled from the keyboard, no software required, and i generally just keep it on solid white anyway.
6 Apr 2009
Liverpool
Makes sense all looks good when done but so much to control and get right.
28 Oct 2009
Earth
same here couldnt stand icue and it spiking cpu randomly with its background processes , ended up getting rid of the corsair fans and now I just buy that can be controlled by argb at least so everything controlled using one software
21 Jan 2008
England
Surprised to see mine reaching 70C with the cooler I have - but after a bit of googling apparently that's quite low!
Might try this undervolt malarkey, though I expect it won't increase performance since it's not throttling.
18 May 2010
London
I found it did allow the cpu to boost to its max speed.
Mines at -15 atm and it is boosting just as much as it was at -30.
Anything more than -15 for me was unstable.
21 Jan 2008
England
I've only just done it, but it's looking good so far. Scoring higher in cinebench and lower temperatures. Not bad for a 5 minute tweak! It is boosting to full speed consistently which it wasnt before, despite it not being near the thermal throttle limit at any point.
I went for -30 with PPT 102, TDC 72 and EDC 102.
Just have to do a longer test now to see if it's really stable.
24 Jun 2022
Manchester
I've been stable on -30 all cores 5800x3D.
I wasn't so lucky with that on my 5950x. It would crash when all cores set on -30 when idle to very light use like open a browser. No issues max load though. I had to use specific values on best to worst cores which worked out nicely in the end.
3 Feb 2017
Mondas
Get those chipset drivers updated as this can make a big difference if you are not reinstalling windows.
