What are you ACTUALLY going to use it for?
There's almost no real world app that would get you to 100%.. the idea that 2 thick 360s couldn't deal with a CPU and GPU is crazy. In recent years we do seem to have become over sensitive about this sort of thing.
Also, CPU temp isn't water temp, you may well find that adding the GPU makes basically no difference to the CPU temp.
I have my 5800x and 3080fe in a loop with 2x 360 and 1 280 and it's hugely within the safe area and that's with just pull fans on basically silent.
yeah guess your right but i have a very good sample (golden like) 4090 strix oc that does 3160mhz sustainable in the most heavy workload games and does not break a sweat...
most 4090s cant get that with air i think i got lucky..
though i did buy some gelid extreme thermal pads to use instead of the ones that come with the ek quantium vector2 for better memory temps. *memory on this card though also runs good @1500mhz without any issues* though i havent tried higher and i wouldnt even want to unless i was trying to break records though thats something i dont want to do, just want a good build for gaming
