- 7 Sep 2020
- Gods Country
Look at the size /shape of those roofs you've posted relative to the flat roof on a small garden building..... There's going to be a lot less uplift from wind.
So you use smaller screws…….they come in all different sizes, why use a hurricane strap and twist nails, when you can use 1 screw……a screw that costs less than a £1 a piece.Look at the size /shape of those roofs you've posted relative to the flat roof on a small garden building..... There's going to be a lot less uplift from wind.
Can screw those in single handed with an impact driver and it feels strangely good when doing so.Can't add anything technical but to say that I used some 250mm screws into sleepers last year.
The next day I could hardly move from all the bracing I was doing with my back to get enough torque to drive them in.
I would get an impact gun tbh if doing that again (in fact I did, I bought a new twinpack from Screwfix when they had the kit with the higher torque gun on offer)
Easily, pilot hole is advised on smaller timbers but I've driven them into sleepers without just fine.Never used screws that big. Do you need to pilot hole? Will a standard impact driver get them in?
Yeah, you'll have to cut some no matter what - unless you use fittings to get the drop; but that cut seems even worse than just using the chop saw lol.
Yeah front and back have the fall. Sides aren't supporting anything so just cut to the smallest height (generally the rear). Then when you clad in OSB you can cut the fall into it/snug to the roof. Roof joists run front to back so sides are just holding it square.Ah do you cut the front end vs the back end to get a fall on the "flat" roof and work out the differential on the timber walls in between?
Oh wow I didn't realise that! Sounds good, that'll be why there's more floor supports for the front/rear.Yeah front and back have the fall. Sides aren't supporting anything so just cut to the smallest height (generally the rear). Then when you clad in OSB you can cut the fall into it/snug to the roof. Roof joists run front to back so sides are just holding it square.
TBC --- I am pretty broke at this stage.Not adding any windows?
Physically or financially?TBC --- I am pretty broke at this stage.
... Or bothLol both man. My hands are crippled. Heading to Portugal today so pausing for a bitPhysically or financially?... Or both
A mistake I used to make was letting the pressure get to me. A lot of jobs are rushed by self inflicted deadlines etc. Nothing worse than midjob contemplating how you'll do it better next timeReally enjoying these threads, is kind of giving me inspiration to tackle the jobs around the house we bought back in December - but I'm a complete DIY novice! I'm between do it yourself and save on the labour, and you'll definitely regret trying to refloor downstairs after you start and mess up within 30 minutes.
A mistake I used to make was letting the pressure get to me. A lot of jobs are rushed by self inflicted deadlines etc. Nothing worse than midjob contemplating how you'll do it better next time![]()
Looks pretty dark in there. Would be a good addition and I know you're loaded.TBC --- I am pretty broke at this stage.
