Caporegime
- 13 May 2003
- Warwickshire
I've just placed £50 at a bookies that on the darkest of nights, you, your wife or her boyfriend
Is that a... niche?Workshop lights - a bit Gucci sofa and I ran out to complete this side fully. It looks OK from the back tho!
Not sure I can fit the bifolds tomorrow they weigh too much for a one man lift![]()
Happy wife, happy life.
Is that a... niche?![]()
Had a day of it today -- I really didn't want to overboard this room, but alas, I ended up overboarding. It is probably for the better - I needed to delete the loft hatch anyways.
Yeeted the loft hatch out and smashed some discover holes in. 15" centers and some floating edges which I'll have to gripfill. None of the lathes have failed, just the lime.
Annoyingly I had to rewire the lights as well - it was a bodge of different things and connector blocks. I also had to delete the shaver socket. I haven't chased a switch in as I'll just be using Hue (lols bodge), so relocated a proper switch up here for emergencies too.
First fix on the sparks done, and some joists put in. I can finally insulate and board over this area, yippee.
I used a different technique this time --- god knows how I go away with doing the bathroom so "easily" - the bathroom was literally 2 boards, with some recesses cut in using the track saw. Not for the life of me could I get it to work this time - so I ended up with a jigsaw puzzle of joint and tapes. Seems OK though -- first coat of joint and tape. Will slather it up tomorrow.
Anyways, new least favourite job unlocked (again).
1. Overboarding ceilings
2. Joist hangers
3. Sanding
If it's the one you mean, Toolstation: https://www.toolstation.com/toughbuilt-scraper-utility-knife/p68606Chaps - where do I buy that fancy ass knife that spins 90 and becomes a scraper?
DrinkingYou missed the end of that sentence....
Happy wife, happy life, happy husband, we'll see about that....
Or
Happy wife, happy life, happy husband, what's he up to?
Have you ever bought the right amount of anything, everDamnit...forgot to buy poly tops. I was wanting to get the soffits and fascias on today![]()
That's... That's just perfect coming from youHave you ever bought the right amount of anything, ever![]()
Username change to "Toolstation parking spot reserved"Have you ever bought the right amount of anything, ever![]()
