Maybe at the high but in the mainstream intel are comfortably ahead. AMD should really be going for 8 cores on the ryzen 5 by now.
You said Intel, comfortable and ahead in the same sentence.
all I hope is that 9000X will not attempt to bring prices back up. 7000X release price was stupid, although could be justifiedthe 7000X series got a price drop.
But 2 years later 6 and 8 core non-3D cpus are basically low end
Yes but its AMD which has stagnated the last few years.
AMD
1600X 6 core
2600X 6 core
3600X 6 core
5600X 6 core
7600X 6 core
9600X 6 core
Intel
7600k 4 core
8600k 6 core
9600k 6 core
10600k 6 core
11600k 6 core
12600k 10 core
13600k 14 core
14600k 14 core
I think what going to happen is Ryzen 9000 series might not be quite as good as 15'th gen, but to do it Intel will be producing very expensive CPU's while AMD's are very cheap, they are at extreme ends.
Intel will want to say "ha... see we can beat them" If AMD are smart they will say "yeah but its so expensive compared to ours we can still make a profit selling ours at a price where you make a loss"
Anyone can make a fast CPU, if you make it big enough on the most advanced node, look at Apples M chips, they are huge, and frankly still not that good... making tiny little CPU's on older cheaper nodes that are still fast, that's a skill Intel don't have.
If i was AMD i would be punishing Intel at every turn, i would be beating them down relentlessly. Never let them get back on their feet.
13600k 14600k are pretty much the same CPU though anyway the MT gap was the same.1600X: 100%
2600X: 110%
3800X: 161%
5800X: 216%
7700X: 264%
7000 series was a 13'th gen competitor, as soon as 14'th gen appeared the 7000 series got a price drop.
AMD need to win on gaming performance with the X3D, if Intel ends up faster in gaming and can get power consumption under control then AMD will have a problem as they are already trailing in single core and MT performance albeit not by much at the high end but more so in the mainstream.I think what going to happen is Ryzen 9000 series might not be quite as good as 15'th gen, but to do it Intel will be producing very expensive CPU's while AMD's are very cheap, they are at extreme ends.
I agree. I game but don't use an X3D chip, the non-X3D CPUs work just fine in gaming as well as everything else. Maybes people should think of it as a seperate fork in production and release. I don't get the GPU analagy either. GPUs are GPUs. They don't do a special gaming GPU, unlike CPUs.Most people aren’t interested in X3D. Its a niche product within a limited market.
Which is why having the best gaming chip helps to sell other sku’s kind of like with Nvidia on the GPU side.The first and second fastest gaming chips are both AMD two generations of Intel later.
The reality is that Intel still leads the way with OEM sales, AMD does well in the enthusiast segment where people build their own PCs and this is mainly for gaming.In your opinion, but reading your last few posts your opinions are a horrible reflection of reality.
So where people choose what CPU they put in their self built PC they are choosing AMD, where people are buying a box because the nice man in the shop said it does the thing and it has RGB its got an Intel CPU in it.The reality is that Intel still leads the way with OEM sales, AMD does well in the enthusiast segment where people build their own PCs and this is mainly for gaming.
