This mod looks cool actually, lots of dynamic NPC reactions which is nice to see now.
With Preset E, you can seemingly use DLSS Balanced/Performance to gain the fps, but still retain the quality (or as close to) of DLSS Quality. It's a no brainer really, even at 1440p.[2024-06-22 01:52:31.954] [info] DLSSTweaks v0.200.8.2, by emoose: nvngx.dll wrapper loaded
[2024-06-22 01:52:31.954] [info] Game path: C:\Program Files (x86)\Steam\steamapps\common\Cyberpunk 2077\bin\x64\Cyberpunk2077.exe
[2024-06-22 01:52:31.954] [info] DLL path: C:\Program Files (x86)\Steam\steamapps\common\Cyberpunk 2077\bin\x64\nvngx.dll
[2024-06-22 01:52:31.954] [info] ---
[2024-06-22 01:52:31.954] [info] Config read from C:\Program Files (x86)\Steam\steamapps\common\Cyberpunk 2077\bin\x64\dlsstweaks.ini
[2024-06-22 01:52:31.954] [info] Wrapped nvngx.dll, using funcptrs from original dll
[2024-06-22 01:52:31.954] [info] INI monitoring: watching for INI updates...
[2024-06-22 01:52:32.391] [info] nvngx_dlss: applied DLSS preset override hook (> v3.1.30)
[2024-06-22 01:52:32.426] [warning] nvngx_dlss: failed to hook DLSS3.1.11+ preset selection code, presets may act strange when used with customized DLSSQualityLevels - recommend using DLSS 3.1.11 / 3.1.30!
[2024-06-22 01:52:32.485] [info] nvngx_dlss: applied debug hud overlay hook via vftable hook
[2024-06-22 01:52:32.775] [info] nvngx_dlssd: applied debug hud overlay hook via vftable hook
[2024-06-22 01:52:34.701] [info] DLSS functions found & parameter hooks applied!
[2024-06-22 01:52:34.701] [info] Settings:
[2024-06-22 01:52:34.701] [info] - VerboseLogging: false
[2024-06-22 01:52:34.701] [info] - ForceDLAA: false
[2024-06-22 01:52:34.701] [info] - OverrideAutoExposure: default
[2024-06-22 01:52:34.701] [info] - OverrideAppId: false
[2024-06-22 01:52:34.701] [info] - OverrideDlssHud: default
[2024-06-22 01:52:34.701] [info] - DisableDevWatermark: false
[2024-06-22 01:52:34.701] [info] - ResolutionOffset: 0
[2024-06-22 01:52:34.701] [info] - DynamicResolutionOverride: true
[2024-06-22 01:52:34.701] [info] - DynamicResolutionMinOffset: -1
[2024-06-22 01:52:34.701] [info] - DisableIniMonitoring: false
[2024-06-22 01:52:34.701] [info] - DLSSQualityLevels enabled: false
[2024-06-22 01:52:34.701] [info] - DLSSPresets:
[2024-06-22 01:52:34.701] [info] - DLAA: E
[2024-06-22 01:52:34.701] [info] - Quality: E
[2024-06-22 01:52:34.701] [info] - Balanced: E
[2024-06-22 01:52:34.701] [info] - Performance: E
[2024-06-22 01:52:34.701] [info] - UltraPerformance: E
[2024-06-22 01:52:34.701] [info] - UltraQuality: E
[2024-06-22 01:52:34.701] [info] - DLLPathOverrides: N/A
[2024-06-22 01:52:49.139] [warning] NVSDK_NGX_EvaluateFeature: game not using custom exposure value or AutoExposure, recommend setting OverrideAutoExposure to 1!
I'm on my second play through attempt of this and it's just not grabbing me and I don't know why, what am I missing. On paper it's a perfect game for me.
Finally bought this for PC. Played on Series X for 15 hours at release but wasn't getting on with it. I'm hoping the game has improved a bit since then.
Any must have mods?
My current mod list if you wanted to check some outFinally bought this for PC. Played on Series X for 15 hours at release but wasn't getting on with it. I'm hoping the game has improved a bit since then.
Any must have mods?
	Maybe a 4090 would help me enjoy it more. I'm determined to enjoy this game if it takes me a couple more years of retriesIt do be like that sometimes. I finished it back when I had my PS5. Not been able to get back into it and play the DLC on PC so that was a waste of money lol.
I'm on coming uo to 500 hours in the game. Completed it twice fully, the remaining plays have been just exploring, enjoying the city driving around and of course playing side missions and things with mods to see how they are with a new lease of life.
It helps that with a 4090 the game is always over 100fps, and that massively helps especially on a mouse that has a fast polling rate (1000Hz) - If I switch down to a lower polling rate or use my productivity mouse, then the experience is considerably lower. I have a new mouse coming this evening that supports Reflex (Turtle Beach Burst Air II) whereas my existing mouse (XM2we) does not, so will be interesting to see if Reflex support on the mouse's end too.
I always find that when a game runs as good as it looks, the overall enjoyment is greatly amplified.
This solely comes down to your character build, and because there are thousands of build combos possible, everyone will have a different experience here. My current build is maxed out Sandy everything, so no hacking or picking off people. Combat is much tougher since enemies skill level is matched to your level, so even if you are OP, they will be too. Makes it a challenge.I'm not sure if my gameplay tactics are wrong or my performance is wrong or if the FPS elements simply aren't that fun. But the FPS elements feels like I need to go into cover and then strategically pick off opponents and tactically wait to regain health. It also feels like the AI has telepathic powers to know where you are
But you don't even have all the achievements yet. So not fully
Now I did it fully![]()
Pc achievements count even less than console ones because you can just complete them on a web app.
