- 9 Nov 2005
- Southampton, hopefully not too hot, or too cold
I just can't get over the droopy saddle nose on those SMP saddles
What is the idea of them. Some people swear by their saddles but I can't fathom what the "limp" bit at the end is for.
They look and seem to review really well, they are just bloody expensive like almost all of these things. Even on heavy discount they are expensive.
Most saddles support you on your sit bones and possibly your manhood.
Selle SMP saddles support you either side of the hip joint, throughout the length of that central dip in the saddle, often with a cutout that takes pressure off your manhood.
Top tip, setup angle on these Selle SMPs is critical, try having the forward bump ~14mm lower than the rear bump.
I got a white Selle SMP Extra for ~£37 off Amazon a few years ago, it did wonders for my turbo time tolerance and also helps outdoors on longer rides.
Works well in combination with my Castelli bibs with quite thin Progetto/Kiss pads, not so good with my thicker padded bibs/shorts.
