The gooderer the bettererBut bigger number is more gooderer
Looking forward to 6 core in 2024? I think it's silly of AMD to even offer them in 2024, very stingy.
6 core should go the way of quad core for new gaming CPU's. In the bin.
6 cores are a good budget option but should not be launching for nearly £300 these days.Looking forward to 6 core in 2024? I think it's silly of AMD to even offer them in 2024, very stingy.
Yep, about £180 tops would be a good place for them to sit imo6 cores are a good budget option but should not be launching for nearly £300 these days.
For budget option, you can get 8 core CPU's new (AM4) for less than that, or go second hand for a Zen4 8 core for less.Yep, about £180 tops would be a good place for them to sit imo
99.9% of all games use 1 to 4 cores and the majority is 1 to 2 cores...I meant as a launch price, I'd expect them to settle lower (£150-160) after some time has passed.
AM4 new, yeah just about but only recently. Cheapest AM5 8 core I can find on the MM with a quick search was listed at £215 and effectively went for £195 as part of a bundle. (wouldn't bother with ebay personally)
I agree though that I wouldn't go down to 6 cores for a gaming build now, I'm reluctant enough to drop from 16 to 8, through a combination of occasional other use and bigger number: better
If motherboards weren't still so expensive I'd be tempted to go 7950x3D now, but will wait to see what happens when these launch.
its just the way engines work.
Games that benefit from 8 cores can be counted on one hand.
am4 and a 5800x3d is the best gaming budget rig people can buy.
zen5 current 7800x3d and upcoming 9800x3d is for those that wants a bit more
Yeah this would be a nice upgrade - Intel QuickSync remains one reason why for some use cases you'd just not consider AMD. I don't know how hard / easy this would be in practice, if there would be legal barriers with patents etc or if it would be too hard to get most software to take advantage of improved AMD encoders due to Intel's place in the market etc, but in theory seems like it would be a big win to improve encoding performance.I'd like to see AMD update the VCE encoder to the same standard as Intel QuickSync... a cheap encoding engine is darn useful but currently AMD is sub standard there
Well they already have very capable encoders on their GPUs, so would assume so but it raises the question of how much power draw/heat/ die space they would incur. (and assuming it would be suitable to be integrated to a CPU)Yeah this would be a nice upgrade - Intel QuickSync remains one reason why for some use cases you'd just not consider AMD. I don't know how hard / easy this would be in practice, if there would be legal barriers with patents etc or if it would be too hard to get most software to take advantage of improved AMD encoders due to Intel's place in the market etc, but in theory seems like it would be a big win to improve encoding performance.
Pointless.. all GPU's do AV1 now, Twitch is doing Beta testing for AV1/HEVC and Youtube already support both of these. NVENC H.264 will be pointless once Twitch fully implement AV1 & HEVC (H.265)I'd like to see AMD update the VCE encoder to the same standard as Intel QuickSync... a cheap encoding engine is darn useful but currently AMD is sub standard there
What i'd like to see is hardware decode support for higher bit depth video like 10bit and colour spaces higher than 4:2:0. Intel have done well on the decode capabilities of QuickSync making editing high end video very capable on mainstream consumer machines. Even the RTX 4000 series can't match intel here. I'm personally not fussed with their encoders as you need a higher bitrate for the same level of quality as software CPU encoding, but I understand for a lot of people it's good enough.I'd like to see AMD update the VCE encoder to the same standard as Intel QuickSync... a cheap encoding engine is darn useful but currently AMD is sub standard there
Plenty of use cases where you'd rather not have to have a dedicated (recent) GPU - Plex/re-encoding videos etc.Pointless.. all GPU's do AV1 now, Twitch is doing Beta testing for AV1/HEVC and Youtube already support both of these. NVENC H.264 will be pointless once Twitch fully implement AV1 & HEVC (H.265)
EposVox is already streaming on Twitch at 4K/HEVC as a Beta tester.
Possibility of 9000X3D have both CCD's with 3D cache and also being unlocked / overclockable, with clock speeds not so limited by the 3D cache this time.
But on a downside, they are saying they wont be announced for quite some time yet according to the slides.
Jump to 7:46
Intel Has NO ANSWER For AMD’s Next Move!
Visit https://piavpn.com/GamerMeld for 83% off Private Internet Access! That's just $2.03 a month!Nvidia's RTX 5080 release looks to be confirmed, next Gen R...www.youtube.com
Rumours at the minute.Hi - Can i please ask, if this is rumours or announced?
encouraging data on floating point multithreaded perf
16 core 9950X almost matching latest 32 core threadripper
Alleged AMD Ryzen 9 9950X 16 Core "Zen 5" CPU Benchmarked In AIDA64 With DDR5-8000 Memory, Up To 45% Faster Than 7950X
AMD's flagship Ryzen 9 9950X CPU with 16 Zen 5 cores has allegedly been tested in AIDA64 benchmark by a user at Anandtech Forums.wccftech.com
and also an utter failure of ability to calculate percentages
I can't even figure out what they did to arrive at those numbers
and a hint that Zen5 will appreciate tuned low latency ram in the end? not familiar with LinX
