Deleted User 298457
Deleted User 298457
Just pinged the invoice. Most folk don't bother with the channel anymore, they just use washers.Oh aye that would be good. I think I require the below. I was going to go galvanized rather than BZP and overengineer. to be honest was half tempted to consider stainless because if the tie rots away it will be a *******!
- 24mm threaded rod (grade 8.8) -1000mm length - Galvanised Steel
- 100m x 100mm x 10mm large metal washer - Galvanised Steel
- Mild steel channel 100mm x 50mm. You will need a piece 150mm - Galvanised steel
- nuts for the 24mm threaded rod (grade 8.8 Galvanised steel)
as for my cladding yes I was going to do the same. Front only in the nice material I posted above, the sides/rear will be in the below:
32/1000 Box Profile 0.5 Thick Polyester Paint Coated Roof Sheet
<h2><strong>Discover our 0.5mm Thick 32/1000 Box Profile Sheets </strong></h2> <p>Whether you are building a roof for agricultural, domestic, commercial or industrial purposes, Cladco Polyester Paint Coated Roofing Sheets will work for your project. Use as a single-skin sheeting, over-cladding...www.cladco.co.uk
