Its the height of the grass pollen season at present its killing me dry weather makes it much worseI'm getting pwned this year. Was okay until last week, now it's dry and I swear it must be a specific plant ***** that's affecting me.
I have a cold as well and the heat isn't helping.
Bleh.
Fexofenadine aint doing nout for me!!!! im dying hereFor Fexofenadine? About that but for 7 tablets, from a local shop. Just seen they are a lot less on Amazon!
Cetirizine has been working for me so far this year.Fexofenadine aint doing nout for me!!!! im dying here
If it helps, I managed to get some Opatanol eye drops online. So far they've been really good for me, and much better than the Sodium Conglomerate drops.Hey peeps, does anyone know if the Otrivine Antistin (Antazoline and Xylometazoline) eye drops have been stopped? Can't find them in stock anywhere, just the normal Sodium Conglomerate ones.![]()
Same. Bought them a week ago and they've helped loads vs loratadine.I bought some Allevia yesterday. Took one this morning and I haven’t had so much as a slightly itchy eye. Highly recommend it to anyone who hasn’t given it a shot.
Careful, that spray can very easily become physically (physiologically?) addictive if you use it too often.Same. Bought them a week ago and they've helped loads vs loratadine.
Plus Sudafed nose spray morning and evening.
What do you mean...As in more sustepible to a blocked nose?Careful, that spray can very easily become physically (physiologically?) addictive if you use it too often.
Yep, our bodies chase a state of homeostasis, persistent use of the sudafed spray basically makes those blood vessels default to a dilated state, so as soon as you stop using it, you end up with a stuffy nose.What do you mean...As in more sustepible to a blocked nose?
Thanks for that, will keep that in mindYep, our bodies chase a state of homeostasis, persistent use of the sudafed spray basically makes those blood vessels default to a dilated state, so as soon as you stop using it, you end up with a stuffy nose.
Actual pseudoephedrine, like Boots brand decongestant, will be a full body vasoconstrictor, without the same risk of localised dependency, but isn't instant relief, and comes with it's own bunch of side effects.
Doesn't look like that causes the same issue as sudafed sprayI've tried most of the brands mentioned and the nasal spray Clarinaze works for me.
It is also anti - inflammatory however, so thanks for the heads up @krooton
