and I only do one bright highlight!! imagine peeps actuality go around the edges 3 times!!All about that drybrushing life for me, edge highlighting can get in the bin until I'm painting a character or special unit/figure
Is that a Grey Knight special boss?
Oddly enough I took delivery of Dragons Gold & Glistening Gold yesterday from Two Thin Coats, not had a chance to try them yet though.Really liking the two thin coats paint range. Picked up the Rhinox hide equivalent and was dreamy to use. Worked really well on the wet pallet. Thinned well and had great opacity.
The finish was also nice. It’s sort of in the range of Satin to matte or matte to satin!
Thanks for the info, the reason I ordered the wet pallet 2 was the reusable sheets, also I bought the extra pack of 15 sheets and the pot holder plus mixing pallet that clip on the sides too.@roman59
I have that wet pallet and it is handy. Instead of rinsing the sheet for reuse I just use a bit of damp tissue/kitchen roll and wipe up the paint. Good to reuse next session.
Some of my paints completely melt on the wet pallet but the two think coats hold together for the colours I tried.
I'd say you're probably looking at a couple of grand for a small army painted to a reasonable standard by a known name like that, probably with a queue too, so waiting a while.
that looks so awsome with all that little detail in there and shading.
3/4th of the way though painting at a guess? with finer details like patchs and unit insignias to come?
Well its been a lot of hard work getting the log cabin the way I wanted it, it arrived on the 30th May and was completed on monday 24th June, the last thing was running a 50 metre armoured cable in a 600 mm deep trench from my house down my garden.I liken this to curating my retro games library. I'd enjoy getting it all set up, making it all look tidy, kitting it out with all the paints etc. Then I'd still CBA to paint![]()
