They all use the same QD OLED panels, it just depends on which 'features' you want with price and availability playing a part.Is one of the 27 inch 360 Hz qd oled monitors the best between gigabyte, msi and alienware or is it mostly a toss up?
Knew all of that, but thanks. It is baffling how poor their availability still is (Central Europe).They all use the same QD OLED panels, it just depends on which 'features' you want with price and availability playing a part.
Apparently the MSI has pretty average responses time at 60hz (a factor if you're using it with a console) - but in the UK the Alienware is the only model that's easily available and is also around 220 quid cheaper than either the MSI or Gigabyte models.
Not really, Dell have a really robust supply-chain model which could just have enabled them to release first.I suspect Dell threw a lot of money at Samsung to get first dibs on the panels
If anyone would like a 12% discount coupon for this, I've got a spare as a result of Dell renewing my employee advantage codes (and I don't need to buy a second Dell OLED monitor...)
I believe mine are UK only and valid until July 14th.
Can that be used on top of the current deal?
i'd like one of those please? i only get 5% with my work.If anyone would like a 12% discount coupon for this, I've got a spare as a result of Dell renewing my employee advantage codes (and I don't need to buy a second Dell OLED monitor...)
I'll PM it to you now.i'd like one of those please? i only get 5% with my work.
If any chance you have another I'm also after one. Np if not, cheersI'll PM it to you now.
I've just sent you one.If any chance you have another I'm also after one. Np if not, cheers
Thank you, fab! I'm stuck between my PG42UQ and 34in QD UW and think this (on an arm) may give me the best of both and job done for at least a couple of yearsI've just sent you one.
