Been saying this for some years now. Better of with a 4K monitor and using DLSS Quality or Performance even than using potato 1440p native or DLSS Quality![]()
Or just use dldsr and have the best of everything!
Or just use dldsr and have the best of everything!![]()
But you can do that at the higher res too for even better IQ
Don't tell me you won't want to jump at a 5160x2160 and will stick with 3440x1440 forever. I know better![]()
And as we all know, the superior res/AR to 4k/16.9
Well yeah of course I will switch to 5160x2160 as it will be the only upgrade from a 34" 1440And as we all know, the superior res/AR to 4k/16.9
In some games, not in others as it's a much of a muchness, I literally showed comparisons of both showing no difference lol or did you forget this back then, the difference now though is even smaller since DLSS dll version 3.7 has been out and we can run every game at Preset ENever understand when you get people like mrk saying can't see the difference
I've been using DLDSR since day 1, but games where it does count, which currently is in none of the games installed and being played lol.
Bet you're still thinking about Hogwarts, that game which still has a broken engine and missing textures at anything below 4k![]()
Depending on some variables, you're probably entering the land of diminishing returns.But you can do that at the higher res too for even better IQ
Upsampling is definitely needed. I can't use dlss by itself at 1440p, it looks crap imo - dlss/fsr only works when the internal res is at least 4k
well, it does play at 140-150fps Cyberpunk with pathtracing!Sure. But enough that I see and appreciate it.
But you would say that. You are a 1080p user for god sakes![]()
