Caporegime
- 18 Oct 2002
0/10 effort - not enough puddles.
Puddles.
No that's not true but it is easy to think that when mainstream tech jurnoes pretend like Cyberpunk is the only RT game.
There's plenty its just that most of them don't provide the same narrative.
Exactly, and the majority are playable in even mid range GPUs from last gen. RT is a cherry on top thing right now and hence why the majority think “is this it”.
It also explains why after all these years CP2077 is still the go to poster child for RT. It is the same narrative from the same suspects and they desperately cling to it as “proof”.
Alan Wake 2 is better at Path Tracing than even CP. it’s the best RT example to date.
Well done RT goes a long way to making HDR standout better, it’s a nice bonus. I like both equally.
I just hope next gen AMD and Nvidia offerings continue to push the envelope.Alan Wake 2 still uses baked lighting for many areas of the game, doorwal light bounce for example is baked in the whole game, even when path tracing is enabled. SO by that measure alone Cyberpunk has better RT than AW2.
From a developers POV, creating a pure RT game without any raster fallback would be very risky unless it was so basic that it ran even the Xbox S.Alan Wake 2 still uses baked lighting for many areas of the game, doorway light bounce for example is baked in the whole game, even when path tracing is enabled. So by that measure alone Cyberpunk has better RT than AW2.
Node wise, isn't Blackwell meant to stay on "4nm" (i.e. a slightly enhanced 5nm which TSMC let Nvidia call 4NM)?Every rumour is that Navi 48 is on an older 4NM process and is using ancient GDDR6. They should be able to get this out this year,especially as they already delayed most of the RDNA3 line-up last year.
Ah my point was that the areas where baked lighting is used are exactly the areas that leverage path tracing amazingly, case in point CDPR did exactly this with Cyberpunk, all doorways use path traced GI and when you open/close a door, the entire room's bounced illumination shifts as the door opens/closes. So we have a real world example of path traced/ray traced GI being used extensively in at least one fully open world game, so there's no reason why AW2 could not have done the same given it's a closed world game with every main area behind a loading screen.From a developers POV, creating a pure RT game without any raster fallback would be very risky unless it was so basic that it ran even the Xbox S.
Let's say a game ignored consoles and was pure PC. And wasn't some basic thing with simple models and next to no textures.
What would it take to run at acceptable rates at 1080P? Even using upscaling from 720P or so, I suspect pure RT without any raster tricks might need 4070Ti or 4080 just to run at the lowest common resolution.
Intel's Battlemage is likewise rumours to be TSMC 4nm.
So it looks like none of these vendors are willing to consider 3nmm or better for consumer GPUs.
What a load of tosh. Is it also not AMD's job to sell more cards, increase market share and stop bleeding customers over to AMD? Honestly...
Yup it's funny as hum has been slating amd recently about them not doing good enough with FSR 3.1 etc. and he even acknolwedges that it is amds fault![]()
AMD had me for a long time (and they still do for the cpu) but they lost me for the dgpu space and it's simply because they are not producing a product that I deem to be worthy for my needs, it is up to only amd to address these shortcomings in order to win me back, not nvidia, not intel, not us, only amd, simple as that.
Good thing we have metro ee, spiderman 2 and avatar to showcase what happens here when no raster fallback....
You have Metro Exodus EE with no Raster mode and worked on consoles... shockingly, at 60fps too!From a developers POV, creating a pure RT game without any raster fallback would be very risky unless it was so basic that it ran even the Xbox S.
Most of it is bloody rubbish and nowhere near the hit it gives.I like RT but rarely miss it when I turn it off.
Exactly, Nv's weaponised it with overdone cost heavy RT/PT, then up the cost next gen-rinse repeat.Most of it is bloody rubbish and nowhere near the hit it gives.
What it means "OVERDONE cost heavy RT/PT"?Is the built for 'RT only(no rasta fall back)' releases Avatar and SM2, or are there more I'm missing, is AW2 RT only?
The hit isn't worth it, probably more to do with that I don't take it in playing a game, I just don't notice it in gameplay.
PR RT/PT in it's best light on Nv's two tech demos CP/AW2 on a 4090, and everyone under it thinks that's the exact same experience they're seeing on their underpowered/cut down bus/memory starved/choking gpus, talking from experience on my journey from the start on 2070>3070+3080>4070+79XTX-enough was enough.
