- 14 Apr 2014
- Hampshire
G3 clay mitt is my go to for claying. I just use extra soapy car wash and go to town. Easy and efficient.
Yes snow foam direct, no rinse.
I personally wouldn't get anything else as I know it works and isn't too expensive.I think I will get a clay mitt too, do you think I could go any cheaper than the g3 or don't bother going cheap?
AG Polar BlastWhat decent snow foam do you guys recommend?
What decent snow foam do you guys recommend? I have tried cheap as in the Demon Foam with it's own adaptor that comes with the container plus in a proper snow foam gun (original Autobrite) and it's rubbish. Also is there any better tar remover than Autoglym Tar Remover which I have had great success with? I just used the last of mine so need to order a new bottle so thought I would check witrh the experts first.
Clay bar for me personally - Bilt Hamber Soft Auto Clay, works fine with water rather than "wasting" quick detailer on it
Bilt Hamber - Auto Clay Soft (200g)
Bilt Hamber - Auto Clay Soft (200g) Auto-Clay is a revolutionary clay made here in the UK. Auto-Clay provides a method of removing harmful contamination from vehicle paint finishes, improving its durability and increasing the gloss level of subsequent waxes. All paint finishes are subject to cwww.cleanyourcar.co.uk
I've just had delivered some Bilt Hamber Touchless and Bilt Hamber Touch on.
Looking forward to trying them out, never used Bilt Hamber before.
What is everyones go to tyre dressing? Always liked Meguiars Endurance
Never considered the difference tyre manufacturer would make - although that explains why Megs endurance sat fine on my old Pirelli's but now slings everywhere on PS4s - even after being left to sit for 36-48 hours.I find Michelin tyres suck at absorbing the gel type dressings and it leaves a patchy finish
Will do if we get an overcast day next week I will try them both outid be interested to hear your thoughts on both clay towels
