I have seen no confirmation for that at all, just rumors at best.
These work on current boards already just not 1:1 with CPU. That won't change on new chipset (reason stated below).
4 dimm slots not working today well are mostly the fault of the board (daisy chain topology of ram slots etc.) and not chipset's. Chipset has nothing to do with RAM, memory controller is inside the CPU for a long time now and is said to be identical in coming CPUs.
X870E boards support faster memory - this is not a rumour and is confirmed. It's similar to Intel, where the Z790 boards support faster memory than Z690 boards etc.
AMD Readies X870E Chipset to Launch Alongside First Ryzen 9000 "Granite Ridge" CPUs
AMD is readying the new 800-series motherboard chipset to launch alongside its next-generation Ryzen 9000 series "Granite Ridge" desktop processors that implement the "Zen 5" microarchitecture. The chipset family will be led by the AMD X870E, a successor to the current X670E. Since AMD isn't...
). 6400MT is already supported even on B650 with a new UEFI - it's not guaranteed, as a lot depends on the CPU (same as with oc) and ram controller in it. And new coming CPUs have apparently same RAM controller, which is 6400MT max 1:1, same a current 7k series. Nowhere in the article it says this is guaranteed on every CPU (same as with current series).
