I tried but no luck, how about you?
I'll be getting a fair amount of reward points once the monitor ships. Could always reorder another one with the discount plus the points and send this one back... if that works![]()
Had a quick go but no luck either, well it does discount but it cleverly only applies discount to the accessories and not the full basket
Still not sure yet.....
You know you want it. You get gen 3 and superior image quality now. Let's be honest, the 40" won't be cheap at all.
Probably be about £1200 tbh, remember we all thought the aw34 would be silly expensive and then thought the aw32 would be even more bonkers but they ended up well priced.
Remember that the 39in being mentioned seems to be an LG W-OLED panel so doubtful that Dell/AW will be doing a model of it.will save that for next year's 40"
Just checked quidco and yup the aw34 was declined so likely this one will be too!
lol. Was worth a goYep same, I even tried removing the items after applying the codes, and it removed the codes along with the item toolol. Was worth a go
I see you just ordered one too, let me know what you think. ETA for mine is Monday, but hopefully it'll arrive over the weekend.
Not sure they can be used again so yeah won't cancel just in case![]()
Always following my lead, psssh!
Unless it really blows me away, it'll be going back within 14 days![]()
