- 31 Jan 2012
- Droitwich, UK
Is that the glossy one?Struggling between this 360 27” and the recent Strix 27 240 WOLED…
Creator mode does not dim, other modes doDoes AW3225QF perform dimming on static images like menu bars/ spreadsheets / office work?
Normally, Panel Health displays a green dot. When a yellow dot is displayed,
Pixel Refresh is suggested to be performed; when a red dot is displayed, it
indicates that the monitor has been used for 7000 hours without performing Panel Refresh
Panel Refresh: To prevent permanent image
retention caused by static content when you use the
monitor for 7000 hours, you can manually activate
this function to refresh the pixels. Alternatively, the
function is activated automatically when the
accumulated usage time exceeds the factory default
setting (7000 hours). The process takes
approximately an hour to complete.
I guess use case is one to consider too, are you going to exclusively be using it for gaming? If so, the general consensus so far for monitors seems to be Glossy WOLED > QD-OLED > Matte WOLED.Yeah that’s the one! Difficult this, I’ve watched so many videos my head is spinning.
Yeah, its also even more obvious when you have them side by side. I use a glossy AW2725DF next to an IPS Dell Ultrasharp monitor (and the Dell monitor is a really great IPS monitor, 120hz too!) but even outside of IPS vs. OLED the panel finishes really do highlight glossy being better.Glossy wins every time having owned both matte and glossy large monitors, OLED or not glossy is just clearer and the way it handles reflections from bright light sources etc.
My QF should arrive tomorrow, and I'm currently really enjoying my DW. Been quietly saying to myself that I'd miss the UW and end up returning the QF.
The fact @mrk isn't missing the UW gives me confidence![]()
Unless a 16:9 one comes out first!
gerryha.medium.com
