The real hope is, with Fibre being far more reliable that any copper based solution, you'll never need a provider's service levels anyway.So who is deemed top tier for service and CS these days?
I’m using a UniFi Cloud Gateway Ultra. Assuming I can just do the same? I did have to put a made up BT username and password in there.There should be none. If you put the Plusnet PPPoE details into your BT router now then everything will just keep working as before as well. BT don't use the PPPoE details so you can put whatever you want in there.
Just put the PlusNet details in on the UniFi gateway on the day of the switch when the internet stops working.I’m using a UniFi Cloud Gateway Ultra. Assuming I can just do the same? I did have to put a made up BT username and password in there.
An ISP in my area installed new poles. The OAP's were kicking off.Are they installing new telegraph poles for fibre installs?
My street doesn't have telegraph poles, or the larger street it comes off, yet last week a random new telegraph pole was installed.
Those in streets that had fttp upgrades... How's it been looking for uptake? (Just noticing open reach/contractor vans etc?) Feels to be around 5-10% around me which isn't bad at all (so far).
My street is 100% I swapped as soon as it was available many years ago the last swapped when they were forced to a year or two ago.Those in streets that had fttp upgrades... How's it been looking for uptake? (Just noticing open reach/contractor vans etc?) Feels to be around 5-10% around me which isn't bad at all (so far).
I've actually found Plusnet to be really good with their service. Especially in comparison to the other 'regular' offerings like TalkTalk, BT etc.Plusnet's Trustpilot reviews are diabolically bad, are they really any good?
The Which review says that Plusnet employ traffic management (throttling/shaping), but I think this must be an error because from my research they stopped doing this in 2017. That would be a dealbreaker for me as cloud gaming is very sensitive to such things.I've actually found Plusnet to be really good with their service. Especially in comparison to the other 'regular' offerings like TalkTalk, BT etc.
We had an issue this week just gone, messaged the support team at 4.30pm and they'd called me back in 15 minutes. They investigated the issue, called an engineer who was with us for 10am the next morning and discovered there was a fault at the exchange which they fixed.
I get that it's all personal experience too - but Plusnet have been good with their service for us.
I think it's probably the usual case of people only being likely to leave reviews when they either have a great experience or a terrible one - and you're not likely to leave a review if everything just works alright.Which seem surprisingly positive about Plusnet and their customer service, so I'm not sure why their Trustpilot reviews are so awful.
