Back from Cyprus yesterday - glorious week away (more like 9 days) but has meant another 'setback' on my return from injury... I've ridden 8 times in the last 37 days and only 5 of those with any effort/purpose (Zwift races/TTT's)! Eeeek! Determined now I'm feeling 100% recovered, been given the all clear from fracture clinic, holiday out the way & new bike ordered. Reset now and 'start again' - but really my aim is to get back into my regular schedule and then 'see where I am' rather than any particular focus/pressure. I know the riding I do will bring me back to that level (eventually) so really no stress about it
Yeah, they sell it at my local farm wholesaler so I just buy a tub when I'm in buying chicken feed if I run out. I am looking at getting some milking goats but I'd be buying them a separate tub.
You're using chicken feed in which cycling products...!?
Goats are fun! Always wanted some (being from a cattle+sheep farm).
@Roady
It's more a question of why wouldn't you do it given it takes seconds and is free as opposed to why would you.
Anything that can be done to prevent them and catch them early on high pressure points should be taken advantage of.
It can be the difference between needing 24-48 hours off the bike compared to a week, perhaps more.
Sores are really useful to understand as they are often unilateral and an early warning sign of imbalance. The sooner a cyclist fixes this, the better. Even the most minor of skin irritation you see will also often be unilateral. Increase the volume and intensity and that same area will likely get a sore.
For me I've ridden many years, so I know the post-ride 'feel' before I'm getting a sore, or even when several hours into a big ride can mitigate them as can feel those 'traffic' areas. I'm even accustomed to have a 'rummage' to reposition some chamois cream mid-ride.
I wasn't saying using a mirror is a 'bad thing' but really once you understand sores and your propensity to them in certain conditions/locations, you shouldn't need to use one. The visibility of a sore is quite late to do anything about it, but for locating the position - you shouldn't need a mirror as can feel where they are!
I've got a leg imbalance, through many years of riding it's impacted my pedal stroke so I 'rock' in the saddle and don't bend my left ankle much through the top of the pedal stroke. That combined through riding normal width saddles with wide sit bones have become accustomed to sores. A wider saddle has helped quite a bit in mitigating them, while a fitter also advising me to reduce crank length to aid the imbalance. Still too soon to see what difference that'll make to my pedal stroke. But at least a combination of things which can be causing them I can change and to gradually reduce them.
Why would I pay that for an average chinese mould frame known for a harsh ride and bad tyre clearances and bad QC, with a £1600 wheelset? (Yes, I know Canyon are a bit better than that these days - at least for their top end frames...)
Paying £3500 for my replacement bike (Tarmac SL7 Comp again with upgraded bars) + £1400 for Zipp FC404's so £1000 cheaper than that (with an extra set of alloy wheels). I know mines 105 di2 vs Ultegra and I'm swapping a few more things (ultegra cranks & wider saddle) which will make it comparable in performance & weight to the CF SLX8.
Obviously the Tarmac Pro is probably more the directly comparable one to it and in an SL8 that's £8000 -
https://www.specializedconceptstore...024-tarmac-sl8-pro-ultegra-di2-376591/option/ so you do get quite a bit more from Canyon, but a Tarmac SL8 Expert is the same price (with SRAM). Top end S-Works is £12,000+ but comes with Dura Ace & is lighter so not that comparable.
Worth noting - in case anyone was unaware - the Tarmac SL7 Comp, Expert and Pro have the same carbon frame. The Pro has 'lighter paint', so really between them all all you're paying for is the different components and not the frames themselves. Only the S-Works is a different carbon frame. The SL8 Comp, Expert and Pro again have the same frame. No paint weight difference. Only with the S-Works again having different carbon. That's why I've been happy getting the 'low' model of the Comp and then just upgrading them!
Been thinking about fueling a bit recently and curious what you guys do for longer rides. From listening to some podcasts around long endurance runs and the talk seems to be to aim for ~90g carbs per hour.
You've already figured this out - if you where maybe riding at 90%+ effort then that's the type of burn. Until you're a paid professional probably better to ride at less intensity and enjoy yourself more... So figuring out what you're burning at that 'mostly 70%' kinda level is what you need to find. There's no harm in over fuelling while training, but obviously not something you do during a timed event. So really play around with different foods for ease and what you can handle to eat (& digest) while training. Different things work for different people. I like cake. But more seriously - I've found the 'cleaner' I eat (granola bars & real food) the better I feel afterwards so tend to prefer to fuel like that. Gels used to upset up and energy drinks tend to make me feel bloated when riding, so I'll only save them until the end of a long ride when I really need the boost.
So after 5 and a bit weeks I've phoned Aviva who have confirmed my claim has been approved, just waiting the offer from the bike department now. So trying to find a road bike now, looking for something for someone who is 5'9, will need electronic gear, preferably Di2 over SRAM, something semi racey, but not necessary full on aero jobby. Want to spend at most £5k including a Power Meter. What's everyone seen so far?
I'm spending 3-4000 on Tarmac SL7 Comps at the moment. 12s 105 Di2 and can't fault it. Does need upgraded wheels though.
Cheers, Van Rysel is a nice looking bike but above budget, Trek looks good so will add to shortlist! Seen a few BMC and Specialized Tarmac Expert on Tredz, but keeping the lookout.
Tarmac Expert is OK - but check my details above - the Comp, Expert and Pro in SL8 are all the same frame (you gain Ultegra & slightly better wheels going for the Expert, but nothing frame+bars wise over the Comp). The VR would be a nice 'project' to see what it's like. TCR always been a good bike for the money - if you could handle the lack of front integration.
Trek like Specialized tend to be overpriced...
Did Goodwood motor circuit today, first ride in ages as I'd broken my big toe into 4. Weather was great and so nice to not see a pot hole
Also
https://www.velominati.com/ not sure if it's been posted before
It's been posted here since before I was here... 2013-ish
