As mentioned above, HDR is to be only turned on when playing HDR games or watching HDR content. Yes to the HDR calibration tool.
i couldve sworn my old LG 38" would only turn on when there was HDR content being shown, but maybe not.
that's a great tip, thank you.If you are on Win 11, win+alt+b turns hdr on and off. It is recommended to turn it on only when for content (turn it on before booting your content not while the content like a game or vid is already on).
Urgh. My monitor was supposed to be delivered yesterday.... didn't even make it out for delivery from the delivery hub. Rescheduled for today, supposed to be here this afternoon.... not arrived and messaging as changed from a specific delivery time range, to "we'll update you with a delivery date". UPS are shockingly ****![]()
looks good mate. Is that a 27' monitor above it and another 32' monitor in portrait ?Finally the monitor arrived.
Still tweaking but have it set up on the stands and cable managed on my work/play desk.
It’s a 4K 27” Eve Spectrum at the top and a 1440p 27” Asus ROG Swift on the left.looks good mate. Is that a 27' monitor above it and another 32' monitor in portrait ?
Shouldn't have installed the dell software or drivers, none of that is needed and eventually it messes with stuff anyway.
Then uninstall it again.Windows installed it automatically.
I will try to uninstall it. But what if windows update reinstalls it again.
I always feel like you 'grow' into your monitor - so if 4k 240hz might not be something your current build can excel at right now but with DLSS (and the 3090 isn't exactly a slouch) you'll be in a great spot right now and even better as and when you decide to upgrade the build.I have been looking at getting the AW2725DF (build in sig). I briefly looked at the AW3225QF but have seen a few comments along the lines of that not being worth it with 'only' a 3090?
A few posts have mentioned discount codes for either monitor, are these only available to teachers, NHS workers and students?
I have the AW2725DF - but that's because I predominantly play FPS games and I really prefer 27" over 32" for that.
Discount codes are typically from the Dell Advantage scheme, a lot of businesses are partners with Dell (or may even have low level support lease contracts) and provided your company email matches their log then you can get access to the codes. Worth having a look here! https://www.dell.com/en-uk/lp/employees
It will be installed each time you plug/replug the USB upstream port in. Don't blame Dell or Alienware, this is Microsoft. The majority of people are too lazy and complain too much about having to install software manually, so Windows allows things like this to be installed automatically.
