Yeah, its improved Zen 4 and Zen 5 performance so its a win winwe all need windows 24h2most of the gains are crazy good for all zen tested, either way you go zen4 and zen 5 performance is going to be excellent
Join me, I've been using it for a while.we all need windows 24h2most of the gains are crazy good for all zen tested, either way you go zen4 and zen 5 performance is going to be excellent
Here's the version you want highlighted below.
- You can download the ISO above and then use Rufus to convert the ISO to installation media on a USB stick
Some crazy gains there.New tests done with Windows 11 24H2
Alternatively, you can download the ISO here. > https://uupdump.net/selectlang.php?id=c1da54e1-2cf1-4534-ba44-61251a6de142i dont have access to the insider program, no ms account, happy to wait though
Click next, uncheck Windows Home, uncheck include updates, click create download package, unzip contents, run the file highlighted below.
That will download the ISO. Now repeat the Rufus steps mentioned above.
Yepselect download and convert to iso?
Yeah, that was my thoughts as well. Cos I could see it either way. Might be that the extra cache mitigates the issues with the older windows and thus sees little improvement, or that it's completely separate and it sees a huge jump on top of its already huge performance. Quick someone with a 7800x3d test it!Very curious to see if the X3D chips benefit the same, or less on 24H2.
I updated a couple nights back and had to download teh 23h2 repair version first, i then got the 24h2 version after it installed. rebooted and checked for updates againWait that's 23H2... i just signed up for the Insider Program and thought that was it
I guess my 23H2 needs repairing first?
