You can get bluetooth adapters with antennas built in so might be best trying one of those if anybody is wanting to buy one.
Do you mean PCI-E ones? I think the only USB dongle design I've seen is the little "nubs".
Wouldn't worry about the make, you can always send it back.Oh sweet, guess I wasn't looking hard enougham I wrong to sketched out by no-name brands though...?
Also heard updating the latest tp-link software helps, been to busy to try it yetGot it, I have a cheapo extension cable so will give this a go tomorrow! But if it was interference, wouldn't it just be totally unresponsive, or lose connection? The fact that I can still move my fingers and press buttons perfectly fine is a little odd.
Re. the Asus dongle, I read the opposite which is why I bought the TP-Link which makes we wonder if the choice of dongle is actually a moot point!
I did some reading and apparently USB 3.0 has inherent interference issues with Bluetooth...? Is it worth investing in a USB 2.0 back panel header to try this? (Don't have any spare onboard 2.0 ports).
Yeah tried it myself but says I already have latest firmware, I have a usb extension do I'm going to try moving it in different areas and see if that helps, I'm in the process of putting a new pc together so I'm hoping the bluetooth on the asus tuf motherboard will workYeah I already did this before I started playing, so not sure if it helped or hindered!
Don't switch them on?Does anyone know how to stop games defaulting to the PSVR controllers when I need to use an Xbox gamepad?
my dongle is in the usb port ontop of my pc so its only a matter of a ft or so away from my right hand, might try and extension from a rear portI also have the issue with tracking on one hand occasionally, can move fingers etc with triggers but can't move the hand (usually the right one) until I shake it around like a mad man for a minutemy dongle is in the usb port ontop of my pc so its only a matter of a ft or so away from my right hand, might try and extension from a rear port
You should but the dongle up as high a possible not under the table.Is your PC on your left side or right side?
My PC is to my front left when I play (just a few feet away, same as yours), and it is always my right hand controller that loses tracking.
I've used an extension cord to tape the dongle right under the middle of my desk (couple of feet away from my PC), so will report back if that makes a different when I try it tonight!
mine is on the right and is roughly around my head hight no more than 2ft away from where I would sitIs your PC on your left side or right side?
I have the same board but was very flakey, probably due to the fact I dont have the antenna connected and means I'll have to go and climb in the atticJust setup my new pc and on-board bluetooth with the asus b650 e works perfect
