- 22 Jul 2024
- edinburgh
Do you think I should the atx12v2
Also with fans I used only 3 pin for argb on this board from the cases smart hub ,
And the phantom spirit had a y split you could join , so joined those , and used its 3 pin to connect to the cases smart hub ? This however left two 4 pins doing nothing from the cpu cooler
