- 14 Jun 2004
yep i have over 100 titles installed (153 including the inbuilt quest default apps) and i have 100gb free at the moment.It really depends on your gaming habits. Virtually all meta games now use cloud saves, so uninstalling/reinstalling is no issue. It's only if you're someone who often swaps between several big games, that this would be an issue.
I've got Asgards Wrath 2 installed, Star wars tales of galaxy edge, walkabout, breachers, demeo, rec room, beat saber, pistol whip and some others I'm sure, all installed, and it does me fine. When batman comes out, I'll likely uninstall one of them (or make more of an effort to finish AW2 or SWtoge).
for the 512 was best option. i just have everything laoded in case i want to quickly swap around or a change. it sone reason i tried Max Mustard and Siltz because it was already installed.
i'll pay some one o change it... i can guarantee i'll break 3 latesh, strip 5 screws, drop the bolt, loose the screws i put down and glare at the quest for 30mins before put it in a box and getting angry at my selfThis was the repair video, and channel, noted for the battery replacement....
I was surprised at how much stripping down was needed before the battery could be replaced, not really being accessible for an easy to replace solution.
Interesting that the improved lenses on the Q3 can, in some situations, reveal some shortcomings in previously coded Q2 titles.
