Regardless of capacity, you will be limited to speed the higher up you go, its even worse with 4 sticks as the imc on 7000 and 9000 are designed with 2 stick configurations first and foremost, getting 4 sticks to play even at 4800mhz can be a massive headache, with the introduction of 24gb dimms (2x24gb kit) you may find compatibility on 9000 better than 7000 but regards to speed wise its tricky to say what you'd land on.
It all comes down to the cpu quality, only when you power on and start tweaking will you know if you have a ok, good or god like cpu that can hit high ram speeds, reviews of x870 with 9000 cpu's do show (2x16gb) 32gb kits can indeed run north of 70000mhz quite easily.
