Report it to the mods and we'll make sure the offender never posts in the MM again
Apologies, it wasn't here. I think the GPU was on TPU and the wanted thread on avforums. My Engrish is often done in a hurry.
I just came back to the forum to take a look at the MM and realised I haven't logged on since 2023 because of the 2fa. I started logging on less frequently until eventually I just stopped. A shame really as I have been reading this forum for a couple of decade and don't any more.I don't post anywhere as much as a used to. Add to that the 2FA which when I'm travelling (which I do frequently), means sometimes I just can't be bothered to log in at that moment.
Pretty easy to make 5 posts in a month if needed, but still something of a barrier sometimes for some.
The 2fa only prompts you once every 90 days... besides, you dont need to log in to actually read it.I just came back to the forum to take a look at the MM and realised I haven't logged on since 2023 because of the 2fa. I started logging on less frequently until eventually I just stopped. A shame really as I have been reading this forum for a couple of decade and don't any more.
Except for the reason stated above where it's not. There was just a day where I decided not to open the authenticator app as it wasn't worth the frictionThe 2fa only prompts you once every 90 days... besides, you dont need to log in to actually read it.
Thanks, that's really good to know!In the latest update, if you log in from the same device it should auto extend your authenticated session
It's a bit annoying as I used to post much more in the past than I do now but can't peruse MM to get a general feel of second hand prices.
I should...Yes you can, just post some more.
I'll do my best to contribute as much as I can.As someone said earlier, working as intended then. Don't contribute, don't benefit. Do contribute, do benefit.
It applies everywhere.When you ignore users does this apply to the MM also. Blocking the lowballers
AVF is the same, deffo a buyers market at the momentMM is much simpler to use but obviously eBay and FB Marketplace get many more eyeballs (and many more morons). I don't think the requirements are hard to keep up with but this place isn't as busy as it once was or at least that's my perception. Quality over quantity.
 forums.overclockers.co.uk
				a 1000 posts, ooffftt will be a while for me to hit that (did it not used to be 500?)Board Usage
