220 miles, door to door so including a diversion to the hotel via Asda and about ten miles through town and the 50mph roadworks sections on the M25 southern section and the same on the M3.
28.5 mpg.
To be fair the wing mirrors themselves were £20 off ebay, bodyshop cost was £60 per cap but they did both for £100, so not awful.They look much better. Mine are also annoying me. Have ordered some carbon fiber "style" ones to keep me going until I decide on the real solution.
28.5 mpg.
How many SPG?220 miles, door to door so including a diversion to the hotel via Asda and about ten miles through town and the 50mph roadworks sections on the M25 southern section and the same on the M3.
28.5 mpg.
Inspection 2 done today, no valve adjustments needed once again, all within BMW spec.
Did however need a new injector due to number 3 failing (12.9 ohms resistance vs the 0.x ohms of the others). Phoned up BMW to enquire as that injector was bought from them back in 2022, turns out it's a few months out of warranty so nothing they can do, and new injectors are on back order across the country until December, and the price is over £300 inc VAT..........................
Found a refurbished one by a UK company on eBay for £90, got it in, all good. Will send failed one to Hack Engineering to be refurbed and then keep spare incase another decide it's had enough.
All in the total for this adventure was £1.2k, half of which is labour due to the valve clearance checks.
For the diff and gearbox oils I opted for Red Line kits now as they're tried and tested for M3s at this age, it's 50/50 mix of MTL and D4 ATF for the gearbox, and the 75/140+ friction modifier for the diff. The oil that came out was clean, which was good to hear.
Full check-up showed I have a few more bits to be done so that will be seen to before the winter:
- All rear bushes
- Outer engine mounts
- Rear brake main copper lines
- Rear brake pads and discs (already bought, sticking with PFC Z Rated pads, and changing the rear discs to StopTech black series like on the fronts, they're excellent and half the price of ATE uncoated OEM discs
- Tiny issue with lower power steering hose clamp, then flush and fill PS fluid with D4 too
- Front anti roll bar d bushes due to very slight play
- Both aux belts could do with replacing due to age related wear
Does it really need all that work? What's wrong with the rear brake lines? Slight play in ARB bushes, isn't that normal? All rear bushes are shot?Inspection 2 done today, no valve adjustments needed once again, all within BMW spec.
- All rear bushes
All of them. Lots and lots.How many SPG?
Yeah I spoke to carservicepacks about it in detail and they have years of customer feedback on the kit combo which seems to be the preferred choice now at this age of the gearbox especially. The diff is smoother too now with the use of the FM. Seems a great oil although the OEM stuff that came out was really clean anyway so at least I know all's well. Gearbox definietly feels about the same as what it used to but 1st and 2nd gears feel a bit more refined at cold than before.I ran the 50/50 MTF/D4 ATF in the gearbox, it was a huge improvement, but expect a tiny bit of noise, it is overall slightly thinner, but I had no wear issues and in winter it was very much appreciated!
The Insp 2 is a weird one.. I had mine done twice at ForzaGB in South Wales, £650 and £720.. local indy's in Chelters wanted >£1K, BMW only charge £810 here.
Good to see yours still going and being well maintained..
The E46 is super sensitive to bushes being on their way, I've done full bushings refresh back in 2016 and the feel and handling transforms from steering feel to how plante dit is at speed to general road comfort. I've done enough mileage now on the 2016 set that it's time to refresh them again hence the advisories for them within the next year or so, so I'd rather get them done and dusted and they're settled for another 5-7 years or so.Does it really need all that work? What's wrong with the rear brake lines? Slight play in ARB bushes, isn't that normal? All rear bushes are shot?
Obviously still a long way off illegal but seems like pretty heavy wear considering it spends 90% of it's life pootling around town.
removed the heater box and fan because they didn't work anyway (and were an optional extra dontcha know!), removed some superfluous wiring and hoses, fiddled with the carb a bit, fitted an air filter, removed the badge bar because I'm not 100 years old, drove to Tesco and bought a sandwich.
Have you got a squeegee in the car for the condensation?![]()
Only EML on because the ignition is on. Goes off after the car is started. A full scan only shows one issue, and that is that my cable is too old to talk with one of the modules.Doing all this stuff, meanwhile the EML is on.
VW activities.![]()
