I'm now 100% sure I will not be having laser eye surgery for my -4.25 myopia. I never got on with glasses, which I only started wearing as needed at 14 - I found they strained my eyes and the low FOV really got to me. I switched to contact lenses at 16 and it felt miraculous in comparison.
In recent years I was wondering about laser eye surgery as my tolerance for contact lenses was dropping. I was showing symptoms of giant papillary conjunctivitis, especially with extensive crusting in the morning, needing multiple lens cleanings throughout the day, and having to reduce my time wearing them from about 14 hours a day to 10-12 or so just to keep that status quo.
I'd always been a monthly contact lens wearer, which I assumed was the best choice for me. With the latest problems, I decided to experiment and bought a bunch of daily lenses and fortnightly lenses. After changing from monthly to fortnightly lenses, my symptoms above disappeared within days. I feel like I have my 16 year old eyes again
I probably won't even try the dailies.
Turns out the monthly ones have high durability and moisture retention (good things!) but at the expense of low oxygen permeability. The fortnightly ones sacrifice the first two for much higher oxygen permeability. Rational to assume the dailies will be even more oxygen-allowing, but I'll just keep them for back up.
I've seen the presbyopia issue demonstrated. My 20/20 vision eagle eyed father is now constantly pulling out reading glasses for close focusing, whereas my mum, who wore glasses almost constantly for short sightedness, now has her teenage eyesight back and no longer needs vision correction at all apparently.
Finally, there are also stories like from this guy:
And that of Jessica Starr - a US weather presenter who was apparently perfectly happy with her contacts but decided on laser eye surgery for convenience, which ended in suicide.
TLDR: I recommend experimenting with contact lenses - as many varieties / types as you can get your hands on until you find the fit for you, as the differences are apparently massive.
The 30 years of wearing glasses implies you're old enough or soon will be for presbyopia to start being a significant issue and even with laser surgery you'll be needing reading glasses some of the time.
That stage of life is another case where contacts are good as you can get multi-focal and even toric multi-focal with astigmatism correction, but if you don't get on with them then glasses are the order of the day until cataracts/eye issues means you need IOLs which can also be multifocal.
