- 6 Sep 2016
32 or 34 at 1440p for me
No scaling used
Would still recommend the glasses though
Your eyesight is precious
And not sure i would go for a va panel
You are aware of va panel smearing?
Did you mention a budget?
That could help determine panel type
Seems we are in a consensus about size and 1440p mostly
But panel type is also something to consider
Not easy nowadays
But if you can actually find a physical store
That has various monitors on display
Might be worth a visit to look at
Pros and cons of IPS and VA though. IPS glow is pretty bad, but with VA it's generally an even level of black.
VA Smearing is most noticeble on dark scenes or difference between light/dark. I don't notice it on Doom Eternal.
Plus it seems curved is more common? I understand higher framerate lessons trailing more, so I'll have to test out once I get a new GPU and sending it 144hz.
Here's video of my samsung 27" (uploading now)
Watch VID_20241117_161435918 | Streamable
Watch "VID_20241117_161435918" on Streamable.
streamable.com
