Caporegime
- 18 Oct 2002
Zero issues on my 7800X3D and 4.6.5 AB.
Interesting, msi AB users take heed.
Weird, my first step would have been to turn off any extra overlays or background software and see if that fixed it. Then only turn on file logging and see what that data says.Interesting, msi AB users take heed.
Did a clean reinstall the other day, no change. People on reddit are experiencing the same, seems to be related to dual monitor setups. It is strange that the other people have almost identical spec to me (9800X3D, 32gb Corsair RAM, 3080).Sounds like someone needs to reinstall windows to me
looks like you grabbed the same stuff as me and likely from the same place if it came from the statesNew memory arrived from the US yesterday and so far its looking promising.
what model of memory?New memory arrived from the US yesterday and so far its looking promising.
I have a TV, an ultrawide and a standard 1440p connected to that very spec. Such a coincidence (see sig), but I don’t have those issuesDid a clean reinstall the other day, no change. People on reddit are experiencing the same, seems to be related to dual monitor setups. It is strange that the other people have almost identical spec to me (9800X3D, 32gb Corsair RAM, 3080).
May or may not help.An update to my desktop stutter/freezing issue: new RAM didn't solve it, resetting bios didn't solve it, another fresh Windows 11 didn't solve it. Not the end of the world as performance is still amazing, just annoying.
Thanks for that, not quite the issue I have though.May or may not help.
YepAre you on the latest bios?
I reset BIOS to stock (so RAM and CPU running 100% stock), clean installed Windows 11 and it did it just opening settings with nothing installed. Weird one!Any overclocks?
Reset it all to stock and run it for a bit. (Ram, CPU, GPU etc)
It might just be teething issue which will get fixed in the future.
Super annoying but AMD had that tpm issue a while back that they had to fix eventually via bios and Microsoft
