Any particular reason?I’d pick the G93, and I have the 95! So there you have it. Didn’t know the difference before I went shopping.
The smart menu on the 95 is gash, the 93 has a normal style menu.Any particular reason?
Well put!The smart menu on the 95 is gash, the 93 has a normal style menu.
£605, Where do I sign up?Just dropping back in to say thanks all for the recommendation of the 93 over the 95. Just placed an order after seeing it back in stock. It's a whole lot of monitor for what feels like a bargain at £605!
Not sure if I can say exactly as OC sell it themselves, but a bit of searching on a certain deals website might point you in the right direction.£605, Where do I sign up?
PM me your email@Personality+
Really appreciate the thread. Just got mine last night it's the G93c and it's pretty impressive out of the box.
If you could share any profile that would be great so I can have a play around.
Made the switch to hdmi after dp was giving artifacting in hdr in some cases. Then got some dropouts via hdmi so lowered to 120hz seems okay for now...It’s a PITA but once it’s sorted you’re laughing. If you have an Nvidia card you can hack in 3440 (or 3880) x 1440, and for the black screens it seems to be the HDMI cable that’s make the difference. We have a cheap place that shifts that kind of stuff in our supermarkets that does a great cable for not much. I tried Belkin and was disappointed at a premium price, so best of rolling the dice on that one.
I see the 2m one on amazon uk, might give it a go thanks!Well, dunno if you can find it easily but the Gioteck 8k HDMI Cable is cheap and does 240hz at native with VRR no bother.
Yeah I am now 0/3 on hdmi cables for 240hz vrr, the giotek one recommended here had a few dropouts, and two local official hdmi 2.1 ones which were thicker and shorter one was ok for a bit. One was really bad even tho was still "certified" with the holographic sticker and all.It's a nightmare delving down the cable standards hole. I found the only flawless 240Hz experience was to purchase a fiber Display Port cable which surprisingly have dropped price significantly since two years ago.
Has anyone found any games that don't stretch out the screen at the edges? I've got a card that can handle processing the extra resolution so feel cheated when all the games I've tested seem to quadruple the width of objects at the edge with no setting to adjust.
