It didn't have a 3440x1440p setting in the EDID so that killed it for me![]()
39in coming at some point (year?) with a 5120x2160p resolution but not with a 1600p one from what I've seen.Still waiting for the OLED update to the old LG 38” screen with 3840x1600 tho. That’s when this thing gets moved on for me (and even then, moved into another room for assetto purposes!)
I did consider that model myself at one point but just couldn't find a decent deal on it. Think I may try the 39in when they come with 5120res in about a yearI've switched from my G9 OLED to the LG 45" (newer GS model) and it's rather refreshing. The only real thing i'd say the G9 offered and I think it's more down to tweaking is that the colours popped a little more on the G9. Maybe the glossy panel helped here?!
I managed to get it for a good deal from the rain forest place, prime day deal! I now need to sell the G9! Not the easiest thing to ship....I did consider that model myself at one point but just couldn't find a decent deal on it. Think I may try the 39in when they come with 5120res in about a year![]()
Nah, £899 wasn't a good enough deal imo. How are you finding it btw? Can you hear the fan at all?prime day deal!
**** out of luck if you have an AMD card like me thoughFor folks with the G9 who want to use 3440x1440, you can do this reg hack (requires adding again after driver updates, so best to export once done for future double click convenience) - this works for PUBG and does 240hz
Dang.**** out of luck if you have an AMD card like me though![]()
Honestly, I didn't think it had a fan?! I've not heard it if there is one though.Nah, £899 wasn't a good enough deal imo. How are you finding it btw? Can you hear the fan at all?
The early models from years ago when they initially released had loads of popping noise ( plastic heating up etc ), The new one is silent.I don't think I've ever heard any noise coming from the monitor honestly.
Really enjoying my G93SC so far which I have had for 6 months. I start my PC and my desktop shows up, I dont need to navigate through any Smart TV type menus to get there, it really just behaves like a normal monitor. With the latest firmware it now has pixel refresh which I run weekly or so. I havent used the G95, but if its anything like my Samsung TV I cant really get on with those menus. I do think it may have more picture customizing options from various guides I watched, but the 93 was easy to setup and have looking good to me.Hoping some owners can way in and help me make a decision. Going to try and pick up one of these ridiculous ultrawides over black Friday with some code stacking. On the face of it I'd thought the G93SC as it's cheaper but seems to be pretty much the same as the G95SC. Any quick view of the differences for those in the know?
I'm also tempted by the higher res of the G95NC but thats quite a step up in cost and VA rather than OLED. Any thoughts on whether it would be worth the trade off from those who've made their decision? Cheers
Very helpful thanks. Totally agree on the smart menus, all I need is a monitor. Though I might use a KVM to switch in my work laptop but should still be straight forward single input on the monitor. I'll actively avoid the Bixby and Alexa rubbish.Really enjoying my G93SC so far which I have had for 6 months. I start my PC and my desktop shows up, I dont need to navigate through any Smart TV type menus to get there, it really just behaves like a normal monitor. With the latest firmware it now has pixel refresh which I run weekly or so. I havent used the G95, but if its anything like my Samsung TV I cant really get on with those menus. I do think it may have more picture customizing options from various guides I watched, but the 93 was easy to setup and have looking good to me.
My only moan really is the 3 x USB C which I use for KB and Mouse and firmware updates, so you need some USB adaptors and its a tight fit, but once they are in there is fine.Very helpful thanks. Totally agree on the smart menus, all I need is a monitor. Though I might use a KVM to switch in my work laptop but should still be straight forward single input on the monitor. I'll actively avoid the Bixby and Alexa rubbish.
Next issue is the 93 being out of stock at the moment...
