Thank you for the suggestions. I have 2 other brackets already I've used for tvs, one would definitely work but as said might sag. I'll let you know what I settle on.
Noticed on eBay there is a listing for the ideal arm and heavy duty pivot listed: “Ergotron HX Wall Mount 45-478-216 + Heavy Duty Component 98-540-216”
Tbh that’s it solved. Not the cheapest but you’ll use it again and won’t need another + it is cheaper than current new prices.
So I've got it wall mounted and thanks for the help a d eBay reccomdation. I had an old bracket that fitted perfectly. It takes 30kilos so it's no bother. My first attempt was a complete failure as I messed up using a too big drill bit to start and p!it's wouldn't stay in. Second I took my time starting with smallest bit taking it slow and working up to bigger but and perfect. Looks great and I'm going to enjoy some Forza 4 and ETS2 on it later today. I'll post a pic katers.
I had a new firmware update last night V2000, not 100% sure what it included but my black screens seems to have stopped. Need to try some further games, as it was certain games that always caused the black screen.
