- 14 Oct 2007
- newcastle
Just for interest what's a good temp for DDR5 please ? My kit at 6000 CL30 tweaked settings sits at about 53 in stress tests (max I've seen 58)
Only currently have 1 120mm fan in and one out on my 4000d case though atm so airflow not optimized
tREFI is at 55k
Wow I haven’t seen my 7200 cl34 running @6400 cl30 Dominator Titanium at higher than 43c under stressMy F5-6000J3038F16GX2-TZ5NR - stick nearest Cpu max at 50 degrees, the second one 47 degrees. I presume this is because the second one has the front case fans blowing directly onto it and it blocks the cool air blowing onto the first one.
