New CPU not working with upgrade
I don't think the psu is the cause of this, more like the cooler backplate was too tight and crushed or loosened that capacitor or whatever that is which caused the short. Usually the backplate would have a cutout big enough to avoid any chips on the back of the cpu socket or at least be foam backed to protect the chips. I reckon any RMA of that board would blame the backplate and hence user error so would decline the RMA.
I would recommend not using that backplate with the new board.
Not saying you are wrong about the cooler being to tight, but looks like the backplate is a standard AMD plate so the cutout should be perfect for the board.
Found this picture of the back plate fitted to the B450 Tomahawk and it shows the burnt chip is clear of the backplate.
The CPUs and memory have likely survived this. It might be worth finding a local PC shop and asking them to test.
I can’t see how the short between the backplate and cap has happened unless the cap has let go and soldered itself to backplate.
Quick question about a new motherboard, is the MSI MAG TOMAHAWK B550 worth it?
The Tomahawk series was pretty popular when AM4 was current, a lot of them are still running happily. hard to answer "worth it" though, without knowing the context. Is it worth spending a lot of extra money over a similar board just to get a Tomahawk? No, it is not.
What would you recommend? My budget is around £100-200
Can you give some context of what the board is for? This thread is a whopper.
Personally, if you have £200 to spend on an AM4 motherboard you should probably be looking at AM5 instead.
I wouldn't want to spend much more than £100, but does something like the Gigabyte B550 Gaming X have sufficient features for you?
The Strix -F, Tuf B550-Plus, Tomahawk and Aorus Elite are all higher tier boards, but if you don't need the features (e.g. a beefier VRM, 2.5 Gb LAN, higher-end sound, SPDIF) there's not much point.
My pc is for gaming, all the specs are in the first couple posts. I'll be 100% honest and say I have no clue as to what to look for in pc specs but the Gigabyte one supports my graphics card. My dad is now saying about the Tomahawk 650 to keep options open for future upgrades. What's your thoughts on this?
Have you managed to determine what parts of the original computer survived the explosion?
I'm assuming, because it kept running with nothing shutting off by itself, that the rest of the parts are fine minus the motherboard and possibly (old)cpu, and I have also been told that there is a good chance they are fine because it was only a crossover on the backplate. But if anything else is done for, there is still warranty on them.
Are you buying a new AM5 CPU? You can't fit AM4 CPUs into a B650 board.
Ah, okay. From what I can see your requirements are basic and pretty much any board (that isn't awfully cheap/rubbish) would do fine.
I'll let him know that, I didn't even realise.
Yeah pretty much, with the msi b550, would that have out of the box compatability with the ryzen 7 5800x because I dont think I could stomach going through what I went through with the last motherboard
B550 does not automatically have compatibility with Ryzen 5000, but realistically they all should by now.
Felt like I should update, since my last post I have got my new motherboard, gigabyte b550 gaming x v2, and I have successfully installed everything including the new cooler and all is working. Thank you to all who helped and/or gave their two cents, it's much appreciated.
Good to hear you are back up and running. :)
