Golf Thread
I’m looking to go back into a forged club. I was fitted for s 300 dynamic gold shafts. I see a lot of the kbs tour lite shafts, how do these two compare? Similar?
Try them and see.... Hard to say off the bat without knowing your swing/tendencies but KBS will potentially launch higher...
I've been in N.S. PRO MODUS3 Tour 105 for last 4 years....love everything about them in terms of flight/feel etc.
It's all just dependant on what suits you best. I wouldn't personally just pick a shaft at random and try using it - Get a proper fitting.
Ive got the kbs tour 130 x in my iblades. Love them but that with my swing, transition speed and and dispertion tendancies.
I came from PX6's and do prefer the KBS
I am thinking about adding a club or two to my bag. My current bag is:
Driver
5W
4H
5–9
PW and SW
Putter.
I am in two minds I would like to add another wedge and possibly a 3W. On courses I play there is a couple of long holes and I seem missing the length of shot from my 5W or hybrid. Wedge wise I have improved with the two I have but there has been a handful of time when I have had a choice between a half swing with a PW or a full SW and it only just making it. Or my other option is to stick with what Iv got and just get more proficient with them.
Driver
5W
4H
5–9
PW and SW
Putter.
What loft is your SW?
Driver
5W
4H
5–9
PW and SW
Putter.
What loft is your PW? I'd go for a Gap/Approach wedge between your PW and SW first of all personall. Especially given what you say. Usually it'll be around 50-52 degrees but if your SW is 54 it may be that your PW is a low-40's setup, my PW is 42 so my next club is a 48-degree wedge and then 54-degree 'SW'.
There's definitely room for a 58/60 then? My current gaping is 50/54/58.
And that too :p
Although personally my 60-degree is easily my least used club, I wouldn't take it out the bag but I only really use it for bunker shots and short-sided chips, normal chips I use my 54-degree.
Driver
5W
4H
5–9
PW and SW
Putter.
3 wood and another wedge sound ideal.
But worth checking your yardages / gapping if you can first...
Get 3 or 4 reasonable shots with each club and average the yardages
I do need to revisit this, I did mid season last year and this really help me improve, especially with club selection on the coarse. But I don’t have numbers for sand wedge.
And that too :p
The cobra speed zone PW is 42.5
Yeah, similar to me and I'd definitely be looking for a 'gap wedge', probably around a 48.
FWIW I've got a Wilson Dynapower PW at 42 degrees, that can carry about 115-120 and my 54-degree wedge (not the set wedge, Mizuno T-24) is about a 85-ish carry so if I just had those two a 100-yard shot would be a problem. My 48-degree T-24 is about 100-105 carry so sits nicely in there, the gap so to speak :p
I was thinking about 48 or 50, yep it that 100 yard shot can be a pain.
Strange one today...
4 ball better ball comp today.... Went out, played off the medal tees which had been moved back for the first time since the front winter tees.... Found out on the 16th tee from other members that nothing will count as the comp on Wednesday had played off the forward winter tees..... Greenkeeper had just decided to move it cause it's a nice day here....
It's always slightly odd for us.... Cause we are a small private club but play over a public municipal course... our comps are played over Wed / Sat and Sunday...Simply due to the fact not all member can play on a single day etc...as it's public....
Disappointing....Comp potentially redone later in the year...
On a plus side - Shot 72 gross (+3) with my own ball. Pleased with that....
5 bogies, 2 birdies, 11 pars. Solid golf.
Birdies number 17 and 18 for the year, plus 1 of 5 rounds without a double bogie.
Last comp over Seafield course (smaller one) - start next week on Belleisle (longer course)
Been feeling recently like the scores haven't really been reflecting my game, as in generally hitting the ball 'ok' but not really hooking up a decent score.
Don't think I've posted these but played The Kendleshire on Wednesday and actually went on a tear for the front 9, +4 gross with a double-bogey on the first (and no birdies, just a par fest) but fell apart on the back 9 for +20 overall, but good signs of being able to score when I get things clicking nicely. After that I thought it'd be a good idea to do the roll-up at my local, only 9 holes but taking it to 27 for the day! Shot 48, about where I've been (46-49 ish) there for the past month or longer but meh.
Then decided to pickup a new putter, got an email from Clubhouse Golf for the Wilson Infinite Buckingham that I've been thinking of for a bit now (going from a Wilson Infinite blade) and it was £109 including a dozen Wilson Duo Soft 'TRK360' balls so how could I refuse?
Yesterday I went to my local but they've decided to drop the usual Friday Roll-up when there's a comp which was an 18-hole stableford and I/we only planned to play 9 so instead we did a 2v2 scramble match for the lols, did well though, made some decent putts and in general the new putter felt good.
And that leads to today, plauing in the 18-hole stableford comp and well, it clicked!
First hole I chipped in for birdie, instantly started thinking the "No good round starts with a birdie" rule :p But just continued playing decently, and putting very well.
Shot 37 on the front 9 with 3 birdies (including a 2 for that pot :D), previously my best over 9 at my local was 40, and followed that up with a 39 on the back 9, no birdies though :( :p
76 gross, +6 and 46 points! 46! I got called names, and rightfully so :cry:
28 putts total on my garmin but I could putts from off the green of which there were at least 3.
Handicap looks like it'll go down 3.6, it was an 8.4 score differential so >10 below my handicap for the 'exceptional scoring'.
Great stuff but how does your handicap go down 3.6 shots? in one round? It's an average of your best 8 of last 20....
There's a thing called Exceptional Score Reduction and basically that makes up most of the drop...
Going into the round my handicap index was a 21.2 (had got as low as 18.1 but drifted up basically this year to date as just not playing great and knocking off decent scores) so the score differential of 8.4 is 12.8 below my index which triggers the above.
If the difference is between 7 and 9.9 they apply a 1-shot reduction to all of your most recent 20 scores, or effectively an 'extra' -1 to your index on top of what the round would normally give. For a >10 difference, like mine, it's 2 shots off my most recent 20 scores.
So 2 shots for the Exceptional Score Reduction and a further 1.6 for a good score replacing a mediocre one.
quick question guys..
what is your height and shaft length?? im 6"2 and have been "fitted" for a 1 inch longer shaft??
Im not sure on it though..
Not always a simple as that...
I'm 6ft3" and half inch longer in irons and wedges, std in driver and half in shorter in 3w....
But I'm also 2 degrees upright in my irons...
fair enough - just seems wildly excessive cut for one good round...
Kinda, but I can't really complain having just scored 46 points :cry:
If I somehow don't win the comp with that though...
5'8 and standard length for me
