Found this for a grand total of £7.51 including delivery. Reviews seem good too.I don't mind waiting. Which one did you go for?
What's the best stuff for sealing wheels? Some kind of wax or sealant? Is GTechniq still good?
Collinite 476 is what I use. I've heard some of the wheel sealant is longer lasting.just use the same you use on the bodywork
wheels are still painted, they are exactly the same
They also say its better heat resistant, but it will take well over 1000 degrees, by which time you wont have any tyres leftCollinite 476 is what I use. I've heard some of the wheel sealant is longer lasting.
I have a tired old Nilfisk washer from 2012 from looking at my amazon history!
https://i.~ibb.co~/svPgC60L/Screenshot-2025-03-11-at-10-17-48.png
I'm looking at replacements and before I push the button on an AVA P45/P55 does anyone have any other recommendations? I will only use it for the car and like the 40ft soft hose on the AVA's as well as the specs.
I've wasted much of the day so far looking at reviews and youtube tests etc. I was initially looking at the P45/55 GO but I want 10-12m of hose and the Easy P50 looks more right for me..The AVA stuff is nice and don’t think I’d look at anything else now
Got an Evo P60.
is chassis wash/wheel arches a need - Later added a long right angled lance with KarcherI then wouldn't need any additional extras.
AVA Easy
AVA Easy may be smaller than many of the other AVA models, but it has good stability, power and plenty of pressure due to its unique design and metal pump. It has a hose reel and a dedicated space for the power cable. The handle can be easily folded down, making it easy to take the washer with...avaofnorway.com
12m hose. I then thought about after market foam canon and gun but most of the reviews seem to say the AVA foam canon is pretty good, did you find it fine? I then wouldn't need any additional extras. Looked at the Karcher K4 but that needs a ton of extras to do what I want.
No it’s pants IMO. I’ve used cheaper ones which have been better
Thanks, is yours one of the older or newer type ones? The new ones have metal fins and it seemed to get good reviews compared to the original all plastic one.
Just find it drinks the liquid and the suction hose is terrible.
Thank you very much. We are very proud of it.Unused to use megs for many years. Now I'm an Garage Therapy tyre serum convert.
Is ordering from Ali express ok?Found this for a grand total of £7.51 including delivery. Reviews seem good too.
You just need the adapter for it to fit a Nilfisk. I paid a few quid on Amazon. The Nilfisk snow foam attachment is absolutely pants.I think autoglym was a reccomended one. Not sure if it would work on my nilfisk I'd have to check
