As long as he's running an updated version of Windows 11 it's there otherwise else should they be using? Windows 10 is dead shortly
	Even my work pc have it lol.![]()
Latest version of Windows 11, as I said not everyone has it
Something is borked on your windows then.
True, mean its not the feature I thought it was which would dynamicly adjust the monitor refresh with the content so 24 FPS actually matches so movies don't jitter on monitors with Hz in the multiples of 30/60 but my dream was broken, Seems only Apple can figure out how to do that (granted on a phone and ipad pro).Well I'm not fussed, everything is flawless! Also good thing, it means it's not turned on![]()
That refresh rate is the same as neil79. Why not try to see if setting the refresh rate to 120 Hz and see if it shows upOut of my 4 displays, 3 are DP and 1 is HDMI, that 1 has Dynamic refresh rate greyed out, says its not supported. Its a 165Hz AOC display.
Not that I use use it for any of them anyways.
They're all set to 120Hz already, its not my primary anyway, I use it mostly for mini cable box but still have it hooked up to my PC.That refresh rate is the same as neil79. Why not try to see if setting the refresh rate to 120 Hz and see if it shows up
				how long until nvidia releases its 6.4GB vram cards?Apparently the new transfer model uses 20% less vram.
 sorry 6gb with 400mb ddr4True, but the transformer image quality is far superior so that kinda makes sense.also a trash title as its still using 50% more than the cnn model at every res its only improved against its bloated self!
Does this work on 23H2?
24H2 gives me too many issues.
Don't know, I'm still on 23H2
Me too and don't see it. My games run fine and look great so maybe not a big loss.
23H2 is not the latest version of windows, and now we know why you don't have itDon't know, I'm still on 23H2
