is it possible to clock a Q6600 to 3GHz on Stock Cooler? Ive scanned through the thread but couldnt find a direct answer.
Am running at 3.6 (3.4 in previous screenie) on the stock cooler on my g0is it possible to clock a Q6600 to 3GHz on Stock Cooler? Ive scanned through the thread but couldnt find a direct answer.
Thanks Easy
The FPO/Batch number for this one is L726A951.
it's already on the lowest ratio and running @ 850MHz, just wont go higher. I do have 8GB though, but i'd rather have more RAM than less RAM thats slightly faster.
. What is the maximum voltage i should be looking at?, bearing in mind that it only just hits 60C under water at this point.EIST and C1E.I have disabled EIST (Ehanced Intel Speedstep Technology) in the BIOS but when I run CPU-z I can still see the muliplier and fsb changing when the machine is idle!
How do I disable Speedstep on the Abit IP35
3.9...
I know this Q6600 (G0 stepping) can go higher but my RAM is holding me backit's already on the lowest ratio and running @ 850MHz, just wont go higher. I do have 8GB though, but i'd rather have more RAM than less RAM thats slightly faster.
Specs in sig.
Im thinking that i have got a bad clocking chip, needs 1.5v in bios to be stable at 3.4. What is the maximum voltage i should be looking at?, bearing in mind that it only just hits 60C under water at this point.
When people quote voltages, are these in bios or cpuz? because at idle my vcore droops by 0.05v and anything up to 0.125v under load, is this normal?
Alex
Hmmm my G0 does 3.8 on 1.5 and the temperature is only 42c idle on water. Your temp seems too high, what water cooling is it?
If it's already at 60c i wouldn't go higher any higher on the voltage.
Stable?
The system is still here and is in a closed case, so if you have a programme you want me to install and some benchmark I can have a look at giving it a run if I get time.![]()
1.150 v, I thought default was 1.280v?
